From google and on here it looks like the only two options for converting to power steering are the OE style slave cylinder and the Borgeson kit. Ive seen the rack and pinion kits but were not going that far with it. Personally, I would rather go with the Borgeson kit. Is there any reason not too? Ive seen the posts about raising the caster and that is already in the works.
Nick
I put the Borgeson kit in my non PS '67 last year. I love it!
It also enabled me to go to a smaller diameter steering wheel, which at 6'2" and 225 lbs is a lot easier ingress and egress for me. I used the Grant #930 wheel.
I don't understand what all the fuss is about. I installed a factory power steering relay rod and valve along with a good hydraulic slave cylinder and have not had any issues. Much less $$ and everything bolts up like the general did it.
Nick
Nick there is another option. Electric PS!! C7 Corvettes have electric PS and it is great. Do a Google search for C2 electric PS kits.
I have R&P and love it. Every late model car has it now because it's the best option, although electric is taking over because it can be computer controlled. But I understand if people want a steering box to make it look somewhat original but it's not.
The big difference (fuss?) is that the Borgeson kit uses a modern progressive boost steering box that is much more responsive to the amount of boost needed at varying levels of driver/steering wheel input than the old GM system.
The old GM system provided a constant amount of boost all the way from dead center to full lock. The Borgeson kit provides a variable amount of boost, increasing from essentially none at dead center to full boost with max steering input. it is not over boosted or "twitchy".
Drive one of each and the difference is startling. The Borgeson kit feels like a new car type system; the old GM system feels like, well, a 50 year old car......
I understand what you are saying but how much does this system cost. Is that really necessary for a 50 yr old car to drive on weekends.
Your comfort and convenience have a value. If you get all the parts and install it, it's about $1000. Shopping it out to a competent/experienced shop, $1300-$1400. Your geographic area may raise or lower the $$ Dennis
I respect you opinion but were are just not going to agree. For a few hundred dollars you can install the factory unit, on my 67 it made a world of difference over manual steering.
If you want comfort and convenience and the feel of a modern car why not buy a new corvette.
Yup. After working for 45+ years I am fortunate enough to be able to afford some comfort and convenience choices. I recognize that others may not be at that same point in life.
It's kinda like which seating class you want to buy on an airline flight - coach, business, or first class. I'm glad I can finally afford to pay for more legroom on longer flights!
Reason: Typo
What would the effect be of not increasing the caster with the Borgeson? Is it necessary? That's the only part of the install I don't think I'd feel comfortable doing on my 64. Dave
I don't understand that it is required, but I'm not sure why anyone would not want to do it.
Increased caster has some benefits - better straight line tracking, and quicker "unwinding" return to center after turning.
Increased caster does increase the amount of force required to turn the wheel - which is why it is not recommended with manual steering. With the power steering conversion that becomes a non issue and the other benefits can be realized.
With the included power steering mount, which groove on the crank pulley does the belt line up with. Refering to the borgeson kit. Need to order pulleys also and thats turning into a headache with what seems like way more options than I remember. Its getting a vintage air kit also so I need to figure that into the belts. Thanks
Nick
Can the caster necessary for the Borgeson, 4* from what I've read, be obtained without messing with the A-arms ? Dave
I would need to dig out my paperwork to be sure of this, but my memory is that the shop that did my alignment (they specialize in old cars) was able to get 3*+ on my 67 with out reworking the A arms. It did take a lot of rearranging the shims. The new shims do look all bright and shiny!
I have had mine for just over a year now, and it works just fine at that setting. I suspect 4* may be a recommended "optimal" setting, but I can tell you mine works just fine at 3*+!
Reason: dig, not dog......
