Powerglide transmission question!
2023 C2 of the Year Winner - Unmodified
2020 C8 of the Year Winner - Unmodified
2020 C6 of the Year Winner - Unmodified
2020 C2 of the Year Finalist - Unmodified
2017 C2 of the Year Finalist
2016 C2 of the Year Finalist
Getting my buddies 63 coupe ready to sell. I know the powerglide has two gears, but my question is regarding the console! "D" is obviously for Drive, but are you supposed to be able to downshift to the letter L ? There is no ability to do that in his car , so I'm thinking the letter L is just there for looks!
JMills (09-03-2017)
By definition, a Powerglide has 2 forward gears. And you can use both of them............try it.
Larry
Larry
Received 6,943 Likes
2015 C2 of Year Finalist
It's quite a learning curve. I never drove one until last year and behind a 427 no less. But putting it in D let's it start in low and shift into high. But you should be able to keep it in low. And low gear winds out too.
JMills (09-03-2017)
Are you sliding it to the left before you pull back to low? Maybe there's a shifter issue keeping it from sliding to the left to clear the stop for D
JMills (09-03-2017)
I had a 67 Chevelle with a powerglide and my 3 year old Son downshifted the car into park while going 40+ MPH. It had a console T shifter with a top lock button and the insert wouldn't stay on the shaft with the spring in it and then the spring got lost. He accidently bumped the shift lever throwing it into park and the rear end locked up. My guess is your shifter may be the problem. Can you pull the shifter into low after starting up the car?
Thread crash...I'm still looking for a good 63 SWC with a powerglide. PM me details if you can.
mmaturo (09-04-2017)
Cool. Found it. and no reserve. hmmm. I might get killed by my wife if I tried to head up to Chicago that weekend (my son has his 1 year b-day party the next weekend). If only this would be at the Kissimmee auction in Jan...I would keep my string going there. Love the white, not sure what I think of the saddle having not seen a 63 with it in person. If this was red inside I would be on a plane.
Your car is my ideal combo. I get the rarity here no doubt.
