running a large engine
Old Sep 23, 2017 | 08:56 AM
mainman55's Avatar
mainman55
1st Gear
Default running a large engine
if you where running a 427 ci in a 1966 corvette with no AC,would that large of a engine heat up the interior of the car?
Old Sep 23, 2017 | 09:07 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
While the car is moving it's not bad. Coming to a stop is where it gets warm. But it all depends on out side temp.
Old Sep 23, 2017 | 09:15 AM
66BlkBB's Avatar
66BlkBB
St. Jude Donor '13-'14-'15-'16-'17
I think it would depend on the exhaust. On my car with side exhaust it is not overly warm even in the summer months. I would think with the under car exhaust that the heat from the engine and exhaust would heat up the cabin fairly quickly, especially in the warmer weather conditions.
Old Sep 23, 2017 | 10:09 AM
Lotsacubes's Avatar
Lotsacubes
Our '66 BB car is only used for pleasure so don't recall ever driving it when it's cooler than mid-60's and never with the top up. We're in the south so cruises with temps in the 80's to 90's are common. My wife and I usually drive with the vents almost turned to the max blowing air on our laps. Yes, it feels warm under the dash, but with the vents open not uncomfortable. Engine temps 180's when cruising so normal. Even when caught in traffic and closely watching temps creep up it's still not intolerable.... but you can definitely feel the engine heat rising. If it's so hot requiring AC we don't take the vette. Bottomline, not objectionable enough to discourage you from the BB. Cheers
Old Sep 23, 2017 | 10:43 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
More of an issue with coupes. The rear window creates a greenhouse effect. In the summer a convertible with the roof off makes it a non issue.
Old Sep 23, 2017 | 10:50 AM
MikeM's Avatar
MikeM
Heat makes horsepower. Does a large engine make anymore horsepower idling than a smaller one? How much if any? How about 30 mph?
Old Sep 23, 2017 | 10:58 AM
cv67's Avatar
cv67
St. Jude Donor '05
they are a larger heat sink than a sbc wouldnt worry too much unless you drive in the middle of summer. Can always add ac...small price to pay for having that brute torque...do it!
Old Sep 23, 2017 | 11:59 AM
Bubba63's Avatar
Bubba63
Lots of articles on the forum about heat and noise reduction. Three twenty-seven owners
with a sea of silver on the floorboards trying to reduce heat and noise. I don't see it getting any better with a big block.
GJM
Old Sep 23, 2017 | 12:41 PM
68hemi's Avatar
68hemi
C1 of Year Finalist (performance mods) 2019
GJM
The fiberglass firewall and floors absorb and let a lot of heat in the cockpit unlike steel that will reflect more of it. Another thing is that the 50 year old firewall grommets for things like speedo and tach cables dry up fall out and let a lot of heat in. Insulate the bottom side of the floors everywhere you can and also on the inside of the body everywhere you can. The original A/C in these cars is marginal at best and the cooling is as well with the radiator and A/C condenser laying in at an angle rather than standing up straight like in the C1s.
Old Sep 23, 2017 | 03:02 PM
DJH's Avatar
DJH
I'm running a 454 LS6 as a driver engine in my numbers matching '66 convertible with factory side exhaust and there is minimal under floor heat. I also added a DeWitt custom aluminum radiator and Stewart stage IV pump with a 7 blade HD GM fan. No engine over heat and no objectionable cabin heat.
Old Sep 24, 2017 | 02:03 AM
SonnyAK's Avatar
SonnyAK
We have a '66 L72 conv w/sidepipes and take some pretty lengthy trips in it. Top up/down, rain/shine, cold/hot and really can't imagine that it's much worse than a SB car under similar circumstances. I think the coupe would certainly feel hotter (either engine) but only due to the less airflow though. When stuck in traffic while cruising through Biloxi, Mississippi during the heat of summer, lacking AC is going pretty much suck no matter what you're in.
Old Sep 24, 2017 | 11:26 AM
65 fi's Avatar
65 fi
I use to own a 67 427/400. My answer to you is YES.
To running a large engine
