total timing
Old Sep 28, 2017 | 10:30 AM
Timer/56's Avatar
Timer/56
2nd Gear
Default total timing
1956 corvette, 2 4 bbls, 327 cu in with HEI ignition, what is total timing..no vacumn advance..??
Old Sep 28, 2017 | 10:42 AM
DansYellow66's Avatar
DansYellow66
Usually pretty close to 36 degrees combined initial timing + all centrifugal timing - no vacuum advance.
Old Sep 28, 2017 | 01:51 PM
Timer/56's Avatar
Timer/56
2nd Gear
Default timing for 56/327
Thanks Dan..nice car..will use your advice..any idea at what rpm?
Old Sep 28, 2017 | 02:53 PM
leif.anderson93's Avatar
leif.anderson93
Between 2500-3000 RPM you want to be all in
Old Sep 28, 2017 | 03:01 PM
Powershift's Avatar
Powershift
Ideal for street driven cars is somewhere around:
Initial advance - 12-14 degrees
Centrifugal - About 24 degrees, and all in at 2500-3000 RPM as stated by Leif and Dan.
Total of both = 36-38 degrees
Small block Chevies like the TOTAL on the high side (38-40 degrees) whereas the big block cars and Fords like it on the low side (36 degrees).
This assumes you have the correct octane in your gas to prevent detonation. Don't dismiss this important point. Failure to assure this is a recipe for a new engine.
You can back off the initial and/or total number to eliminate detonation.......at the expense of horsepower.
Larry
To total timing
