Help to identify Holley 6210
Old Oct 8, 2017 | 09:26 PM
moonframer's Avatar
moonframer
Default Help to identify Holley 6210
Anyone know what car my Holley List 6210 date 0354 came off of?
Also the date? Thanks, Jim
Old Oct 9, 2017 | 03:17 PM
rongold's Avatar
rongold
From: Putnam Valley, New York. Amateur Radio Operator K2NS
Default Holley 6210
The Holley 6210 is a spreadbore replacement for a Rochester Quadrajet, and was not an OEM carb. It never was original equipment for any car. As for the date, I think the first digit is the year---zero could be 1970, 1980, 1990, etc. The 354 should be the 354th day of the year.
RON
Old Oct 9, 2017 | 03:36 PM
GUSTO14's Avatar
GUSTO14
The Holley 6210 is a model 4165, 650cfm, spreadbore carb that has been used by a lot of folks over the years to replace a Quadrajet. Some find it easier to tune than the Quadrajet.
GM never used it from the factory, so it's most likely that someone has installed it to be able to use a spreadbore manifold on the engine, or to replace a Quadrajet.
There is some additional info on these carbs and their more common use in this thread...
https://www.corvetteforum.com/forums...nt-carb-3.html
Good luck... GUSTO
Old Oct 9, 2017 | 07:23 PM
rongold's Avatar
rongold
Default Holley 6210
A spreadbore carburetor will not fit on an intake manifold made for a squarebore Holley carb. Besides having the wrong carb, you will also have an intake from a passenger car or an adapter on your original manifold.
RON
Old Oct 10, 2017 | 08:25 AM
dcamick's Avatar
dcamick
2019 C1 of Year Finalist (appearance mods)
I run a 650 Holley Spread Bore on my 61, 283.... mounted on an Edlebrock Performer Intake. BTW....No Choke!!
Runs Great!!!!
To Help to identify Holley 6210
