holley spreadbore gm replacement carb..
Old Jan 8, 2011 | 11:23 PM
  #41
scottyp99's Avatar
scottyp99
I have heard knowledgeable people say that the Holley spreadbore is not a very good carb. It doesn't have some of the nice tuning features of a Quadrajet, and lacks some of the nicer things about regular squarebore Holleys, too. This is just what I have heard.However, if you use one, and it does what you need it to do, and your happy with it, then God love ya! I am actually thinking about getting one myself.
Scott
Old Jan 9, 2011 | 06:47 AM
  #42
jb78L-82's Avatar
jb78L-82
Scott
Scott,
That is why I keep repeating my experience with my 4175 over the last 25 years. I have heard the same from people but just as many people say the 4175 is great and the Qjet sucks, so I call it a draw and default to my personal experience with the Holley 4175 and the OEM Qjet on my 78 L-82 over 33 years. The only caveat is that my experience is on a mostly stock lightly modified L-82. It does not pertain to high HP extensively modified engines. As a good basic reliable 4 barrel carb, the 4175 has the tuning features that one would need: Idle adjustment, electric choke, vacuum secondary spring tuning, and easy primary jet replacement, and easy rebuild ability. I believe that the 4165 squarebores have external float adjustment-I have never needed that adjustment and it still would be easy to do on the 4175-take the float bowl off (easy), adjust, put float bowl back on (easy). Many of these issues are just NOT easy to do on the Qjet-that is all I am saying and once a qjet's calibration is off, the fun really begins! Isn't it funny that to rebuild a qjet correctly, you have to send it to a specialist?-it's a carb for pete's sake.
Old Jan 10, 2011 | 01:56 PM
  #43
Snoopysvet's Avatar
Snoopysvet
Originally Posted by markdtn
I had one on a 455 Pontiac for many years. Worked like a champ.
Hey I had a 6210 on a Pontiac 455 about 25 years ago, it was a great carb.
Old Feb 1, 2011 | 10:50 AM
  #44
Locke's Avatar
Locke
Default Holley Spread Bore conversion
Did anyone have throttle linkage problems?
My '69 (bought used a few months ago) came with a cobbled together bracket which I remade out of nice materials, so...the geometry may not be stock. Thats' the opening disclamer!
I find the cable attaching ball on the Holley is much closer to the fixture on the bracket which holds the carb end of the cable. This results in very little carb opening. In addition, I measured the length the ball moves from closed to WOT; on the Q jet it moves 2 5/16", on the Holley it moves 1 3/16".
Assuming I could get the cable end far enough away from the ball stud on the Holley, I'm guessing it will get alot more throttle for much less pedal movement.
The Holly throttle bracket, part number 20-32, did not work for me as it is designed for the newer square plastic clip on the end of the cable as opposed to the older round end that clamps in place.
Did any of you have simular problems? Maybe I just need to find a stock throttle cable bracket.
Locke
Old Feb 1, 2011 | 01:47 PM
  #45
fauxrs's Avatar
fauxrs
Originally Posted by Patrick73
Lars recommends a 6.5 or 5.5 power valve. ZIP has a step by step installation guide with photos of a Holley 4175/4165 in their C3 Tech Section:
Just did a carburation weekend with Jeff Smith of Car Craft magazine, we determined exactly the same thing, 6.5 is what we installed with the premise that I will try a 5.5 over the upcoming months (he didnt have a 5.5 in stock).
Carb was good at WOT and idle.
Old Feb 1, 2011 | 03:14 PM
  #46
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default 6210's
Originally Posted by Alan 71
People say that there's a way to be able to use the stock air cleaner base, with crankcase breather, by bending the arm the tube interferes with. Can anyone explain that procedure, please?
Regards,
Alan
I have been using Holley 6210 spreadbore double pumper since 1973 on my 68 327/350 and will continue. Just put a Holley renew kit in it 6 months ago. Still like the carb after all these years.
I modified my 68's air cleaner drop base when I installed the Holley 6210. I removed the vent tube and covered the hole with a freeze plug using silicone sealant to attach it. In 1973 I did not know if I would move the tube back to install the original QJet. Moved the tube to a more rearward position on the air cleaner base and brazed it. Works great for me using the original drop base 68 air cleaner.
Old Apr 4, 2012 | 12:53 PM
  #47
dan7674's Avatar
dan7674
Navigator
Default Air cleaner fit
I have a 76 with the holley spreadbore. I am using the complete air cleaner setup from the 78 dual snorkel on it on a Weiand manifold. No problems with clearances. I had the single snorkel one first.
The only modification was to cut the breather tube to the valve cover and extend it using a piece of rubber hose.
This is a manual transmission.
Old Apr 5, 2012 | 11:33 AM
  #48
TWINRAY's Avatar
TWINRAY
Originally Posted by timgman
Is anyone running the holley spread-bore gm replacement carb..
thanks
When I bought my '69 it had a spreadbore on it. Believe it or not, it only ran on Amoco Premium. The seller told me that's what he used so I started using it. It was then (early '70's) the most expensive gas. Probably .369/gallon when others were .349. I tried Getty premium and ended up draining the tank it ran so rich. I think I tried another brand and it did the same thing. Obvioulsy the carb wasn't set up right (I guess). I put a Q Jet on and haven't looked back in 37 years.
Old Apr 5, 2012 | 01:19 PM
  #49
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
this is like the thread that never dies....4 years from original post
Old Apr 6, 2012 | 11:36 AM
  #50
TWINRAY's Avatar
TWINRAY
Old Apr 6, 2012 | 07:51 PM
  #51
7t9l82's Avatar
7t9l82
i have my old one on the shelf (double Pumper) didn't these have the backwards idle screws turn out to lean or am i mistaken?
Old Apr 7, 2012 | 03:39 PM
  #52
scottyp99's Avatar
scottyp99
This is the thread that never ends,
yes, it goes on and on my friends.
Some people posted on it, not knowing what it was,
and they'll continue posting here forever just because
this is the thread that never ends.............
Keep the shiny side up!
Scott
Old Aug 15, 2012 | 08:44 AM
  #53
oldalaskaman's Avatar
oldalaskaman
sorry , couldnt resist posting, this thread has some excellent info, many thanks
Old Dec 21, 2013 | 06:33 PM
  #54
chickenman's Avatar
chickenman
Default Lars......THE Quadrajet Man!!!
This thread never dies.....and one of our very own (Lars) can rebuild and engine test a Quadrajet for a very reasonable fee....I used his services to rebuild my 1974 Quadrajet to keep everything "numbers matching" (for future owners because it makes no difference to this driver), but his expertise and ability along with reasonable fees should be mentioned in all Quadrajet threads. I'll admit that the Quadrajets are far more complicated to rebuild than a Holley, but when you have an experienced mechanic with the proper tools, man do they perform well. Just thought I should mention one of the great contacts we have here on our Forum.
Old Dec 21, 2013 | 07:36 PM
  #55
7t9l82's Avatar
7t9l82
i used the double pumper version on a couple different corvettes one manual one automatic and i liked that carb on both. the fact is no mater what carb you put on a car some adjustment will be needed. i prefer a mechanical secondary.
Old Dec 22, 2013 | 02:46 PM
  #56
lars's Avatar
lars
Originally Posted by chickenman
(Lars) can rebuild and engine test a Quadrajet.
I also do quite a few of the Holley 4165/4175-series spread bores, and they can be made to run quite well. My test engine will accept any Q-Jet, and any Holley-based 4-barrel, including the spread bores.
Lars
Old Dec 22, 2013 | 03:05 PM
  #57
63vette427's Avatar
63vette427
Lars
Lars did a great job on my Holley Spread bore. I bolted it on and was ready to drive..
