63 300hp afb carb gasket
Received 1,048 Likes
C2 of Year Finalist (appearance mods) 2019
If you’re using the original spacer that goes between the carburetor in the intake you should use the ones with the four holes in them 2 gaskets and a spacer.
Received 1,974 Likes
The installation sequence is in your AIM. It's a good idea to plug the "heat slot" ports in the manifold with Welsh or NPT plugs. This should mitigate the percolation issue.
If you don't have the spacer and stainless steel heat shield, I'm sure they are available from the various Corvette parts vendors.
Duke
Duke
Duke
Duke
