1960 corvette
Old Oct 22, 2017 | 03:23 PM
rick charles's Avatar
rick charles
Default 1960 corvette
I have a 1960 corvette and would like to put the correct trans . In it , would the correct trans . Have the cast ron case or the aluim. Case ........ Need help rick
Old Oct 22, 2017 | 03:38 PM
1snake's Avatar
1snake
Cast iron.
Old Oct 22, 2017 | 05:08 PM
65GGvert's Avatar
65GGvert
Editing and deleting this article because the information is apparently not correct and I don't want someone who searches by key words or just skims this thread to get incorrect information.
Old Oct 22, 2017 | 05:10 PM
GTOguy's Avatar
GTOguy
Cast iron case with aluminum tailhousing used until mid 1961 Corvette production.
Old Oct 22, 2017 | 05:17 PM
1snake's Avatar
1snake
Originally Posted by 65GGvert
Late '50s and early '60s Corvettes used an aluminum case,
100% incorrect. ALL 1957 -1960 Corvettes with RPO 685 (T-10 4 speed) had a cast iron main case.
Old Oct 22, 2017 | 05:35 PM
rick charles
Default 1960 vette
1 snake : Thanks for the info . Serial # 00867s102743 early or late car ? Straight shifter or reverse lock out shifter ? Rick
Old Oct 22, 2017 | 05:39 PM
65GGvert's Avatar
65GGvert
I just copied and pasted it from a BW information article and thought I'd share it just in "case".
Old Oct 22, 2017 | 05:42 PM
1snake's Avatar
1snake
I would consider #2743 out of 10,261 an early car. Mine is #3714. 59-60 4 speed shifters had the reverse lock-out.
Old Oct 22, 2017 | 05:54 PM
rick charles
Default 1960 vette
Thanks : ( 1 snake ) for the good info ..............rick
Old Oct 22, 2017 | 08:03 PM
rick charles
Default 1960 build dates
CORVETTE CALANDER SAYS : 2743 BUILT ( jan 20 1960 ) AND YOURS WAS BUILT ( FEB 13 1960 )
Old Oct 23, 2017 | 12:49 PM
ejboyd5's Avatar
ejboyd5
Late '50s and early '60s Corvettes used an aluminum case, while the full-size GM units from '57-'60 used a cast-iron case. GM used all aluminum-cased units after 1960, and all manufacturers used aluminum cases up until 1974.
Copied from article about T10 usage in by all manufacturers.
Completely wrong. This post clearly shows the problem of regurgitating internet information when you don't know the answer yourself.
Old Oct 23, 2017 | 01:07 PM
65GGvert's Avatar
65GGvert
This post shows what happens when you don't read the previous posts before you criticize someone trying to help. It's already been posted that the article was apparently incorrect. Some people just can't wait to say "completely wrong". I have a 60 and I saved that article about the T10 transmissions and shared for discussion to help get correct answers. I answer a lot of questions on the forum, mostly electrical or function. Sorry if one was incorrect. Rude posting something that has already been discussed is unnecessary.
Old Oct 23, 2017 | 08:28 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
You've helped dozens of people with complex C1/C2 electrical gremlins with aplomb and expertise -- you have nothing to apologize for...there is not a single person on here that hasn't gotten something wrong now and again... Don't let snarky posts dissuade you from the help you've been providing...
To 1960 corvette
