starter
Old Oct 27, 2017 | 11:40 AM
jlnick54's Avatar
jlnick54
6th Gear
Default starter
I have a 327 motor (62-65) and a 350 turbo trans. I have a 168 tooth flywheel. I need a starter to put in as I bought this from someone and it did not have a starter. what will fit? I have tried at least 7 starters from my local Carquest and they have all not fit. The gap between flywheel an starter have all been more then 1/8" . desperate in looking for help? are there any suggestions?
Old Oct 27, 2017 | 01:02 PM
MelWff's Avatar
MelWff
a 168 tooth flex plate requires a starter where the bolts are at an angle/staggered
a 153 tooth flex plate requires a starter where the bolts are straight across
based on the above are you using the correct flex plate for the kind of starter the block will take?
https://www.speedwaymotors.com/the-t...ck-chevy/28655
Old Oct 27, 2017 | 04:17 PM
rongold's Avatar
rongold
From: Putnam Valley, New York. Amateur Radio Operator K2NS
Default Starter
I don't know of a 62-65 327 block has all 3 holes drilled on the starter pad. I think the 870 block only has the pair of straight holes. You might have an incompatible combination. What came out of the car ??? Did you just put the trans & flywheel in recently ???
RON
Old Oct 27, 2017 | 06:12 PM
jlnick54's Avatar
jlnick54
6th Gear
Default starter
I bought the motor an trans together.
Old Oct 27, 2017 | 06:13 PM
jlnick54's Avatar
jlnick54
6th Gear
RON
I bought the motor an trans already together...
To starter
