[C2] Opinions on the deduction of color change
If I just couldn't pass up buying a yellow car, I would drop it off at the paint shop on the way home, so actually the new color has as much bearing on the situation as the plate, and repro plates are cheaper than paint jobs.
Bill
Bill
Concours Judging began in January 2017 at the Florida Regional. I'm sure they are still learning.
Received 1,843 Likes
Does a $25,000 paint job get a different color ribbon than a $5,000 paint job? Either type judging? I want to spend my money wisely, not just blow it on the color of ribbon I get.
https://www.corvetteforum.com/forums...akeland-2.html
The total points available are 2,200 for all 4 sections, plus operations. There are two levels of award in each class. Just like the flight system, if you score 94% or better, of the 2,200, you receive a "427" Concours award. Then there is the "327" Concours ribbon/certificate for 83% to 93%.
I have not seen this type of judging done. It was done as a "trial run" at Lakeland last year. Other than that, I know nothing.
The best part of finally being financially secure is that I don’t have to “cheap out” on things like paint jobs, oil changes and batteries. I do not feel the need to endlessly argue that my Ray Charles paint job is as good as one done by a real pro.
And even, better ?
I don’t feel compelled to disparage anyone that spends even more than me.
Ahhhh. Life is good.
And even, better ?
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
So far we only have two opinions in dollars of the hit this car would take. $10K+ and $15K for the paint. Actually, the fair way to do it would be by percentage of value to a like car in the correct color. After all, it makes less difference the lower the price of the car is. It cost the same amount to do a like type paint job on a 1966 Impala 4 dr. and nobody is going to ding that car for the same replacement cost of the paint.
I knew when I started this thread there would be a lot of (as always) different opinions but I did not expect it to take this turn. Probably my fault for not clarifying my request for dollar value and NOT judging points. I know the cost of a quality paint job done correctly (taking the car apart and stripping it) will vary somewhat throughout the country but I don't think the hit for the exterior color should be that much anyway. To some it will make no difference if they like the car and the color. OTOH, for someone that wants a truly correct car to the numbers they would likely have to factor in the cost of rectifying the paint and possibly the seat covers.
As I stated previously, I have to consider this even if I like the current color because if I decide to sell it later I will certainly be beat up over it buy the next potential buyers.
I said changing Yel to Red should add $10,0000
The following 2 users liked this post by 65hihp:
60n1st (11-11-2017),
Bill Pilon (11-13-2017)
You asked about a specific color change on a specific car. So of course you got answers in dollars since the quality of the car in question isn’t described.
$15k of $100,000 is 15%; $15k of $50,000 is 30%.
They might be cheaper, but repro trim tags will open up a real can of worms.
You can spot a repro tag pretty easily, and then you've got major problems trying to sell it, as it will present even more problems for the educated buyer. Most will walk away from a repro tag.
"Owner says original engine, trans, rear. 327/350 4 speed, leather but not coded for it. Repo side exhaust and KO wheels, PS, PB (not original MC) and PW. Body off resto 1500 miles ago. Nice car."
#33
If I was the owner I would not deduct anything, if you don't like don't buy
The following 2 users liked this post by LT-1 kid:
Bill Pilon (11-12-2017),
OC-1 (11-11-2017)
#34
Some of you guys will be counting your money when you die. If you don't spend it all on foolishness first.
I thought this was a hobby, not a used car/banking business.
3JsVette (11-12-2017)
#35
2023 C1 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared))
2019 C1 of Year Finalist (track prepared)
I'm with Don. I say changing yellow to red adds value. $10,000 if it's very well done.
Certainly there are those that won't buy a color changed car. But there are a lot of people that don't care what the trim tag says, and a lot more people like red than yellow. And I like yellow.
It has to be a great paint job. If it is, and you like the car, just get it.
#37
Brian VH McHale (11-12-2017)
#40
Absolutely. Change colors to anything you want but keep your rat claws off the Trim and VIN plates.
