[C2] Quick jack
Old Dec 6, 2017 | 07:41 PM
joescvette's Avatar
joescvette
Default Quick jack
Can anyone tell me if a Quick Jack BL5000SLX will work on a 66 and a 78. Thanks Need to get one.
Old Dec 6, 2017 | 08:08 PM
C2 Jeff's Avatar
C2 Jeff
i have that model and with a 65 it works fine. Should work fine with your 78....pretty similar Underneath
Old Dec 6, 2017 | 10:05 PM
leif.anderson93's Avatar
leif.anderson93
Works just fine...
Old Dec 7, 2017 | 02:16 AM
joescvette's Avatar
joescvette
Thank you
Old Dec 20, 2017 | 09:40 AM
dkleather's Avatar
dkleather
2016 C2 of the Year Finalist
I’ve seen promo pictures of them being used passing under the car side to side. Will the BL5000 SLX be okay for using this way on these cars?
Leif? Jeff?
Old Dec 20, 2017 | 09:56 AM
C2 Jeff's Avatar
C2 Jeff
Leif? Jeff?
I have always jacked my car along the frame rails, but I can't see why it wouldn't work the other way.
Just remember that you'll need side clearance when jacking it that way as the car will move to the left or right when lifting.. probably not a problem in a 2 car garage, but in a single car garage, it could be close.
Old Dec 20, 2017 | 10:27 AM
dkleather's Avatar
dkleather
Thanks, Jeff. My problem is that my double garage is only 20x20 feet. The info states the jacks when raised move the car 11 inches or so. That amount forward might cause things to get very close. Going sideways I’d have plenty of room especially since I usually pull into the center of the garage to work. Dave
Jeff, Sent you a PM.
Old Dec 20, 2017 | 11:13 AM
leif.anderson93
Dave,
Your C2 is not quite 15 feet long. With a 20 foot deep garage, don't you have plenty of room using the jack under the frame in the conventional fashion? Sounds like you have plenty of room, unless you have cabinetry, etc in front of the car. Just curious. Either way, you're going to love the convenience of this lift.
Old Dec 20, 2017 | 01:10 PM
dkleather's Avatar
dkleather
Originally Posted by leif.anderson93
Dave,
Your C2 is not quite 15 feet long. With a 20 foot deep garage, don't you have plenty of room using the jack under the framein the conventional fashion? Sounds like you have plenty of room, unless you have cabinetry, etc in front of the car. Just curious. Either way, you're going to love the convenience of this lift.
Lief, I don’t have cabinets but do have other stuff like ramps, which I probably won’t need much any more, air compressor, tires etc. in front. I won’t have much more than two or so feet before my door when the jacks are up if I pull straight in. The garage door is a double so I usually drive in at an angle for more work room so I should be fine. I just wondered about being able to put the ramps crosswise so you could get to the tranny from the middle without having to slide the entire length underneath. Have had to get to that area for the switch and linkage a time or two. Thanks for the help. Dave
Old Sep 22, 2018 | 09:20 PM
awches's Avatar
awches
Might have to try the cross lift method next time I need my car in the air. Had it up this morning to wash the oil pan and some places under there hunting for a small leak. Had seen it done on quickjack's you tube shows but forget about it when needing to get the car up.
Old Sep 23, 2018 | 10:46 AM
Dreamer56's Avatar
Dreamer56
Anyone use the quickjack bl-7000slx for their C5 - one is for sale in my area - overkill but also would work for my other vehicles as well.
Old Sep 23, 2018 | 10:36 PM
SoCalErv's Avatar
SoCalErv
Army
With it fully raised how much clearance do you have under the car?
Old Sep 24, 2018 | 10:11 AM
After38Years's Avatar
After38Years
Consider also the type of garage floor you have. If it is smooth, painted or tiled, the Quick Jack will slide without huge effort. However, if it is bare concrete, the jacks can be difficult to move. If they are parallel to the frame rails you only need to move them a foot or so (mine stay under the car when not in use). If you are sliding them in perpendicular to the rails, you have to move them several feet while dealing with hydraulic lines.
I have the 5000 model. It is not light. The 3500 model may be light enough to pick up and lean against the wall, but you will need muscles for the 5000...
To Quick jack
