[C1] Passenger side generator
Old Dec 31, 2017 | 10:00 PM
bj1k's Avatar
bj1k
Default Passenger side generator
I'm installing the steeroids power steering kit on my 57 corvette and the directions call for moving the generator from the drivers side to the passenger side because the new steering pump is in the way. I have seen some generators are on the passenger side . Did it come from the factory on some years on the passenger side ? I have stock manifolds but the flange built into the passenger side manifold has a different bolt pattern than the generator bracket so it would not be a direct bolt up to the manifold . Is there a aftermarket bracket or a stock passenger side bracket available ? Or do I need a stock right side manifold from a different year C1 ?
Old Dec 31, 2017 | 10:11 PM
Robert61's Avatar
Robert61
My 61 had a passenger side mount. I'll look tomorrow and see if I have the brackets. I do have the generator. I'm not sure how different it would be from the 57.
Old Dec 31, 2017 | 10:37 PM
bj1k's Avatar
bj1k
Hi Robert , I do have the stock bracket that bolts directly to the generator that lets it swivel but the holes are a different width than the holes on the manifold flange on the passenger side . So it looks like it takes an adapter plate of some kind .
Old Dec 31, 2017 | 10:41 PM
Robert61's Avatar
Robert61
I'll look and see what I've got.
Old Jan 1, 2018 | 01:05 AM
K2's Avatar
K2
Yes it requires an adapter plate and any Corvette parts supplier such as Corvette Central, will have them.
https://www.corvettecentral.com/58-6...-340-or-401112
Old Jan 1, 2018 | 07:32 AM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
For 55-57 the generator was on the left side.
The generator moved to the right side on ALL 58-62 cars. SOOOOOOOOOO, simply set it up as it was done on 58-62 cars. Too easy!
Of course, this will also change the location of the voltage regulator and associated wiring.
Old Jan 1, 2018 | 05:09 PM
Robert61's Avatar
Robert61
I have the generator but no brackets
Old Jan 1, 2018 | 08:13 PM
bj1k's Avatar
bj1k
Thanks for that K2 . That's what I needed to know . Simple enough . I was a fabricator for over 40 years . I'll whip that up tomorrow.
Old Jan 1, 2018 | 08:39 PM
Robert61's Avatar
Robert61
Why not make the bracket just fit your passenger side manifold and not use the adapter?
Old Jan 1, 2018 | 11:59 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
One of the purposes of the adapter is to raise the generator so the belt won't rub. It's a good idea to use it.
Old Jan 2, 2018 | 09:49 AM
DZAUTO's Avatar
DZAUTO
Originally Posted by jim lockwood
one of the purposes of the adapter is to raise the generator so the belt won't rub. It's a good idea to use it.
Agreed!
Old Jan 2, 2018 | 10:14 PM
K2's Avatar
K2
If you slot the lower holes that bolt to the manifold, you can easily align the gen pulley to the water pump pulley. Also be mindful that clearance under the hood is pretty tight so you want to keep it as low as possible.
Old Jan 3, 2018 | 05:28 PM
bj1k's Avatar
bj1k
That's what I am working on now but got side tracked today.
Old Jan 3, 2018 | 05:34 PM
bj1k's Avatar
bj1k
After seeing the picture that you posted it gives me something to go by . I made many complicated brackets for street rods over my 40 years of auto restoration in my business . That one is simple .
To Passenger side generator
