65 door panel question
Those 2 screws screw into the inner door metal.
Received 6,944 Likes
2015 C2 of Year Finalist
those are in the door structure it self. been a while since I looked at them but they might be glued or riveted to the door. or just made into it
I have the doorpanels off of my 66 and there is a rivet besides each armrest screw hole. so I guess that the plate you are talking about is riveted to the door. can take a closer look at it tomorrow when I am at the car again. if you don't have an answer by then
The 'nut-plates' are solid aluminum riveted to the fiberglass door shell. Pop-rivets will do if you are not worried about it being facotry correct. Nuts and bolts will do the same thing....and...using some of the 2-part catalyzed adhesives currently used in automobile construction can also be used.
DUB
DUB
Easy Rhino (01-12-2018)
