[C2] priming
Old Jan 13, 2018 | 06:00 PM
prestige6's Avatar
prestige6
Default priming
Just had my 67 427-435 rebuilt. I installed the heads and everything else. Adjusted the valves according to cam specs. I have been trying to prime the motor. I have oil coming up through the lifters, but nothing coming up to the rockers. I have read that solid lifters won't pump up to the rockers. Unless running. Is this true or should I just keep priming? Here are a couple of pictures, of the oil in the lifter valley and the two tools I have.
Old Jan 13, 2018 | 06:06 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
rotate the crank shaft
Old Jan 13, 2018 | 06:17 PM
tbarb's Avatar
tbarb
What are you using to prime the engine, if the priming tool does not seal the oil galley that runs around the lower distributor area there will be a internal oil leak. Also, there was a change in the 1967 time frame from a groove in the rear cam journal to a groove in the block and if the parts installed are not correct there will be an internal oil leak.
Old Jan 14, 2018 | 09:01 AM
prestige6's Avatar
prestige6
ttt
Old Jan 14, 2018 | 09:07 AM
Nowhere Man
that is only in 65-66 BB (961,962, and 942 casting)
Old Jan 14, 2018 | 09:17 AM
prestige6's Avatar
prestige6
Been rotating and priming. Still nothing past the lifter valley. Every once in awhile I will see a bubble come out of the rocker hole.
Old Jan 14, 2018 | 09:24 AM
Nowhere Man
the only thing I will add your primmer tool does not have the semi circle grove at the bottom like a real 65-74 GM BB dist.
Old Jan 14, 2018 | 10:30 AM
tbarb's Avatar
tbarb
I would verify if the camshaft has the groove or not in the rear bearing journal plus what rear cam bearing was installed.
From memory, the 67 camshaft does not have a groove and the block has a groove for oil to flow to the lifter gallery and the rear camshaft bearing is different.
Someone will explain the actual difference.
Old Jan 14, 2018 | 10:34 AM
Nowhere Man
The 67+ B.B. have oil paths like SB. So no grove in the rear of cam and standard cam barrings. So unless the barrings spun and now the holes don’t line up there is something else wrong. I am getting behind my skill set here.
Old Jan 14, 2018 | 10:46 AM
SWCDuke's Avatar
SWCDuke
'65 and '66 big blocks require a camshaft with a groove in the rear journal and a "three hole" rear cam bearing. The groove is the oil transfer passage to the lifter galleries and valve train via the two small end holes in the bearing. The center hole is the passage to the crankshaft oiling gallery.
So you need to audit the manufacturer/part number of the installed cam and rear cam bearing to ensure they are correct for those first two years of big blocks.
I don't think the Federal Mogul replacement SHP cam has the groove, so it must be machined in the field... not sure about other vendors.
For '67-up the oil transfer annulus and passages to the lifter galleries were machined into the block, so only a single hole was required in the rear cam bearing and no groove was require in the rear cam journal. It's okay to use a grooved rear bearing cam in '67-up big blocks, but not okay to use a non-grooved cam in '65/'66 big blocks, and they must also have the three-hole rear cam bearing.
Duke
Old Jan 14, 2018 | 11:00 AM
Robert61's Avatar
Robert61
If he had an early block with an incorrect cam it wouldn't be oiling the lifters. It's more than likely the metering device keeping the oil from climbing the push rods.
Old Jan 14, 2018 | 11:09 AM
MikeM's Avatar
MikeM
Yep!
That battery powered drill may be adding to the problem? It may be a little short in the britches.
Old Jan 14, 2018 | 11:14 AM
Nowhere Man
He states he has a 67 351 block so the early cam and barrings should not apply
Old Jan 14, 2018 | 11:22 AM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
If you oil at the lifters you are good to go, you have filled the filter, and the oil passages to the bearings, the oil pump can take over when you fire it up.
Doug
Old Jan 14, 2018 | 11:26 AM
AZDoug's Avatar
AZDoug
I doubt that drill is turning 300 RPM under load. My 110V Makita bogs down quite a bit when the oil starts to get everyplace it should.
Doug
Old Jan 14, 2018 | 11:37 AM
Powershift's Avatar
Powershift
Yep!
My first thought. I would prefer to see an electric 1/2 drill with a side handle that puts outs some real torque.
OP can hookup a psi gage to see what oil pressure he has when priming. Drill should be around 700 RPM output.
Larry
Old Jan 14, 2018 | 11:45 AM
prestige6's Avatar
prestige6
It's a 321 block Casted in may of 67 . My car was produced last week of July.
To priming
Old Jan 14, 2018 | 11:54 AM
Robert61's Avatar
Robert61
Put it in run it. You're done. I've primed many motors with a speed handle. Turning by hand is enough to get 50-60 lbs. If it's bypassing it doesn't matter how fast you spin the pump.
Old Jan 14, 2018 | 01:31 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
It takes a loooooong time to get oil to the rockers on a big block. I had the same trouble as you, finally buttoned it up, started it, med fast idle and oil running all over. Good to go.
Old Jan 14, 2018 | 02:19 PM
MikeM's Avatar
MikeM
I had the same problem years ago with the only solid lifter BB I put together. I used a big half inch corded drill and it pulled it pretty hard.
