1961 Cowl vent template Request
Tether Man
Received 2,014 Likes
2019 C1 of Year Finalist (appearance mods)
Ok...I'm really asking a lot here....
I just purchased a C1 Used Cowl vent on Ebay. My 1961 has no Cowl vent. It was eliminated by the previous original owner due to leaking issues. To complicate issues...Custom paint was applied following the cowl vent removal in 1970. I will need to work around that, if possible.
I am interested in re installing that vent port. I am requesting a template to confirm what I can see from under my dash. a paper template will work.
Any interest please PM me at your convenience.
Best,
dcamick
Best,
dcamick
Best,
dcamick
Best,
dcamick
http://www.zip-corvette.com/53-62-co...therstrip.html
I had the same issue with my 51 Chevy pickup, where the previous owner had filled it in....After careful consideration, I left it filled in, but then again, the truck had vent windows....And I do use the cowl vent in the 62 Vette...
Plasticman
dcamick (02-05-2018)
Best,
dcamick
Best,
dcamick
I have that piece from replacing my hood surround.
Tether Man
Tether Man
Your in luck buddy , I am restoring a 61 right now and have my cowl vent out so it will be easy to send you a template. Give me a phone number I can send the pick to with deminsions and I will get it to you this week. By the way , when I was looking for one to restore I seen one for sale that had vent removed - could it be the same one ? Victor
Guess I'm stumped. The outline of the vent opening should be visible from below. drill a hole in the center and grind until the material color changes.
in fact a bright light should show the outline if the glass was stripped of paint.
if you have the cowl vent, measure equi-distant to the wiper holes. make a template from the vent door lay it down and center it. Drill a starter hole in the center and work slowly outward until the material color and density of material changes.
FWIW
FWIW
Tether Man
FWIW
FWIW
But I like what your saying that was my plan (pilot hole).
Pic of car less cowl vent and windshield washer
This is what I have.
Tether Man
Wow! I would say "that's a template"..
What are the chances of tracing the following on a pc of paper.
The opening of the entire recess (I have a vent for reference) , the center to center of the windshield spray fixtures, the measurement from the hood opening to the vent seal trough, the hood opening to the cowl vent edge at the center position, the edge of the panel, and any known reference from panel left or right to the edge of the vent trough.
That will save you from sending the panel to me......I will be more than happy to pay for the template and ups charges.....
What are you going to laminate in for the vent? So you think that part is still under the patch?
Tether Man
Actually, if I understand you correctly, I have purchased a used cowl vent, screen, hinges and levers on ebay for a 61. I don't believe there is anything other than a cardboard plug and body filler......Is that what you mean? Sorry!
Yes that was what I was asking about. I thought they may have cut it out. I'll figure out a way to make you a good template. If they did cut it out at least you know where another one is. Pm me your address and I'll get something to you unless you decide to go a different route.
Received 3,443 Likes
If I had your car, I wouldn't touch it. The period finish it has right now is priceless, IMO.
Tether Man
I've been very busy. I should get to making you a template tomorrow. I'll post a picture for you before I ship it to make sure it's what you want.
Received 1,901 Likes
Why mess with something that looks damn good as it is?
Now, if you're going to tear the car apart for a total restoration.....then I could see getting the vent back in.
dcamick (02-08-2018)
I tried making a template out of some plexiglass I had but it kept breaking so I figured it would never survive shipping. Here are my measurements. If you want I would ship the old part I have for you to compare or I'll continue to try and make a better template. I just noticed I didn't locate the centers of the radii on of end of the opening. I'll get those tomorrow if needed.
