Shifter rebuild
Old Feb 6, 2018 | 04:34 PM
Dave Witman's Avatar
Dave Witman
Default Shifter rebuild
Rebuilding 66 4 speed shifter. The shifter arm is loose at the bottom in the block. Can this be tighten up some how or welded.
Old Feb 6, 2018 | 05:28 PM
pop23235's Avatar
pop23235
Dave, do not understand. The chrome handle has several wear points. The faces of the square that fit in the "housing" for lack of a better term. The pin that holds the shaft in the "housing" and in early C2's the bellville washer that supplies tension in the "housing" aligned with the pin. Then there is the oval shaped tip of the handle that wears and goes through the gates. Then the shift levers can wear in the gates and on the pivot shaft or the shift rod holes. So what are we looking at?
Old Feb 6, 2018 | 05:42 PM
Dave Witman
Added a picture the shaft is loose in the block.
Old Feb 6, 2018 | 06:34 PM
DUB's Avatar
DUB
Communication or terminology breakdown.
I am also confused. I have tighten up these shifters numerous times and I am lost on exactly where it was loose.
I do not know what you mean by ''loose in the block"???
Is what you are referring to as the "block"...the metal housing that all of the shifting plates slide into and are held in with the big dowel pin???
And this "block"...as you call it is partially in view in your photo in the upper left hand top corner???
DUB
Old Feb 6, 2018 | 07:02 PM
Mike67nv's Avatar
Mike67nv
2018 C2 of Year Finalist
2015 C2 of the Year Finalist
If you mean where the shift lever joins the base, yes, it was welded. A mig-spot weld will cure the issue and shouldn’t show under the rubber shift boot. Guess how I know?
Old Feb 6, 2018 | 07:25 PM
pop23235's Avatar
pop23235
Well, that's a first for me! Glad you got a solution. Remember to index it correctly!
Old Feb 6, 2018 | 08:27 PM
rayvaflav's Avatar
rayvaflav
Yup, me too on my '66. In the midst of rebuilding my OEM Muncie shifter I had the same weak spot. I took it to a local guy who welds (and a welder by trade is a bit of a lost art, I try to send this guy as much work as I can, he has welded my shifter, my clutch pedal shaft and all of the welds in my seat frames. A well restored Muncie shifter is a bit of clunk-clunk heaven, never mind what the Hurst guys tell you.
Ray
Old Feb 6, 2018 | 11:20 PM
Dave Witman
Yes thanks where the lever joins the base. Looks like I need to weld.
Old Feb 7, 2018 | 09:18 AM
pop23235's Avatar
pop23235
Think I’d be tempted to braze that or silver solder.
Old Feb 7, 2018 | 09:50 AM
MikeM's Avatar
MikeM
That problem was common enough there was a TSB Written on it to weld the handle for repair.
I don't have the TSB handy so no number.
Old Feb 7, 2018 | 06:19 PM
DUB's Avatar
DUB
I would do it that way and not think twice about it...and I have welder at my shop also.
Brazing it or using silver solder definitely would hold it
DUB
Old Feb 7, 2018 | 06:47 PM
65GGvert's Avatar
65GGvert
JohnZ says to weld here:
Old Feb 8, 2018 | 05:44 PM
MikeM's Avatar
MikeM
See post #10.
Old Feb 8, 2018 | 06:26 PM
65GGvert's Avatar
65GGvert
Originally Posted by MikeM
See post #10.
I saw it. I posted also, with a picture. A TSB you can't access really doesn't do much.
Old Feb 8, 2018 | 06:49 PM
68hemi's Avatar
68hemi
C1 of Year Finalist (performance mods) 2019
I would be afraid that would not be nearly as strong as a weld and that it may break again, but I am not a welder.
Old Feb 8, 2018 | 06:58 PM
MikeM's Avatar
MikeM
I can't see your picture because I am too lazy to switch out my machine here that runs on XP. Likewise I am too lazy to dig the thing out and post a picture or a TSB number. Rest assured, there was a TSB that described four reworks to the early Muncie shifter and welding the handle was one of them.
Thanks for your confidence in my posts.
Old Feb 10, 2018 | 06:11 PM
DUB's Avatar
DUB
No need to be afraid. TRUST ME...brazing it or using silver solder...there would be no way that it would come apart.
Doing either (brazing or silver solder) would provide such a strong bond strength that there is no way that a person could (by hand) cause the shifter handle to ever come out.
And putting parts that have been brazed or sliver soldered in a vise and try to tear them apart...GOOD LUCK with that.
AS written by someone other than myself:
Tensile Strength of Brazed Joints. Joint strength depends on several factors: clearance between parts, base metal composition, service temperature and joint quality (low voids, good penetration). Joint design will also affect strength. The bulk tensile strength of silver braze alloys is 40,000-70,000 psi.
In this case...I could braze it or use silver solder and it would never fail.
Or read this:
https://app.aws.org/wj/2000/09/0015/
DUB
Old Feb 10, 2018 | 06:19 PM
MikeM's Avatar
MikeM
The TSB actually contained repair for four different issues with the Muncie shifter.
One was the handle coming loose.
One was replacing the lockout "pin" with a cable.
One was welding the lockout pin on the shift body as they broke as well.
Can't remember what the fourth problem was.
To Shifter rebuild
