[C1] 60 door window sweeps
Hey guys, got new window sweeps and they overlap the post channel . can someone tell me how they go . Do the ends insert somehow . This overlap cant be right . Thanks for any advice.
The ends of the window sweeps insert into the bottom of the door post channel bead. The window sweep is the "male" and the door post channel is the "female".
It is important to install the new sweeps correctly or your window will not roll up and down smoothly. Instead of rewriting what I did, there is an excellent write up done by Rich5962. Look at this link:
https://www.corvetteforum.com/forums...lattening.html
Go to post #8 and open the pdf file. The window fuzzy installation starts on page 11.
Again, it is critical to get the fuzzies right for your window to work smoothly.
Good luck,
Terry
Good luck,
Terry
stingrayjones (03-04-2018)
Thank you so much Terry. I thought that but had nothing to go by and did not want to force the connection until I knew for sure . Great help , Thanks again for taking the time .
2018 C1 of Year Finalist
corvette central or keen. You want to buy repo correct ones. Or a nice set of NOS ones. Either way stay away from the ones which were not correct. The non-correct ones do not have a nice curve to them.
Just a reminder that the rear channel felt supplied in the kits in recent years is too thick and will not allow the window to go down in the channel easily. Many have just gone to the fabric store and purchased similar, but thinner, material to use.
Terry
Terry
Again, the reminder was just a heads up for those guys that may not have run across the old threads addressing this problem.
Terry
Get the thinner felt from JoAnne Fabrics; make sure you leave 1" over the top of the rear channel so you can glue it down the outside on three sides - this prevents "roll up" later on...
The following 2 users liked this post by rich5962:
solidaxel (03-03-2018),
