[C1] C1 Front end alignment caster shims
Old Feb 12, 2018 | 04:30 PM
68hemi's Avatar
68hemi
C1 of Year Finalist (performance mods) 2019
Default C1 Front end alignment caster shims
I had it "recorded" somewhere but can't find it now.
There are shims made for adding caster to C1s which is recommended when using radial tires.
What are these called and where can you find them?
Old Feb 12, 2018 | 04:54 PM
Cpe04's Avatar
Cpe04
https://www.corvettecentral.com/c1-5...ims%26catalogs
Old Feb 12, 2018 | 05:01 PM
68hemi's Avatar
68hemi
Thanks, I searched on CC and put in alignment shims an came up with nothing. So, these go on the ends of the front cross member? Did they have another purpose and these are just extras to shim the whole front end out?
Old Feb 12, 2018 | 05:06 PM
Cpe04's Avatar
Cpe04
They go between the frame and front crossmember. The early C1's didn't have them. The later models got the shims.
Old Feb 12, 2018 | 05:09 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
you might consider using 2 on each side
Bill
Old Feb 12, 2018 | 05:16 PM
GTOguy's Avatar
GTOguy
No caster difference between radial and bias-ply tires. More caster= more steering effort when the vehicle is parked or moving slowly, and it also adds high speed stability and better steering wheel return to center. Radial tires will increase steering effort when parked or moving slowly due to their increased footprint and construction. (bigger footprint)
Old Feb 12, 2018 | 05:29 PM
68hemi's Avatar
68hemi
Well, they were recommend for use with radials. I may have the exact reason wrong but I do need something to help with better steering wheel return to center.
Old Feb 12, 2018 | 05:34 PM
GTOguy's Avatar
GTOguy
Extra shims for extra caster will do just that. And radials, with bigger footprints, may indeed need a bit more help returning to center. Sounds like you are right on track, pun intended.
Old Feb 12, 2018 | 05:35 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
more caster will definitely help. the beauty of using the TAPERED shims is that they can easily be added to.
more caster, up to about 5 degrees, helps with return to center and straight ahead stability; especially important if you add power steering.
Bill
Old Feb 12, 2018 | 05:54 PM
AZDoug's Avatar
AZDoug
2017 C1 of Year Finalist
I use two shims on each side of my car. With the slight rake from having the rear end sit a up a bit, it gets me into the 2.4*-2.5* caster range.
Some of the cross member bolts can be bitch to get out if they are original. having the bumper brackets off helps, IIRC.
PS the thick end goes to the rear.
Doug
Old Feb 12, 2018 | 05:58 PM
AZDoug's Avatar
AZDoug
Also, when I went to change my shims about 1995, the original shims were barely there. Galvanic corrosion on the shims made them partially disappear, even though my frame is about as rust free as any I have seen.
IIRC, I believe there was also the remnants of some insulating piece of thin ultra dense paper between the shims and frame top and bottom.
Doug
Old Feb 12, 2018 | 09:06 PM
csherman's Avatar
csherman
2026 Corvette of the Year Winner - Unmodified
2025 C1 of the Year - Unmodified Winner
2019 C1 of Year Finalist (stock)
2018 C1 of Year Finalist
and just FYI 53-55 did not have them
I "think" they were first added in 56...
Old Feb 12, 2018 | 09:32 PM
Jim Rosenthal's Avatar
Jim Rosenthal
This is very useful and thanks, as I am looking at radials for my '57 C1.
Old Feb 12, 2018 | 09:46 PM
68hemi's Avatar
68hemi
PM sent.
Old Feb 13, 2018 | 10:54 AM
emccomas's Avatar
emccomas
Some related info
Old Feb 13, 2018 | 02:01 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Ed, any idea why that rework wouldn't apply to Corvettes built prior to '56 #3175?
Old Feb 13, 2018 | 02:25 PM
emccomas's Avatar
emccomas
Not a clue. It is shown as a retrofit for 53-55 Corvettes, so I am sure it would work, but I cannot figure out why GM specified that VIN range.
Old Feb 13, 2018 | 03:34 PM
jim lockwood
FWIW, my '54, which doesn't have the shims obviously, is stable to at least 75 mph. Too, with little caster, it's easy to steer at low speeds.
Still, I find it curious that only '56s which are unstable about 50 MPH and which fall within a limited VIN range are specified.
Old Feb 13, 2018 | 03:55 PM
emccomas's Avatar
emccomas
Well, it is pretty easy to conclude that all cars after 4156 already had these parts installed at the factory.
I do note that there are a number of parts listed in this TSB. I wonder if cars before 3175 would not accommodate some of these parts.
I don't know why that would be.
Puzzling.
To C1 Front end alignment caster shims
