No, not straight through and as i recall not every main. Curiouser and Curiouser? And again on the suffix "P", I can't find a p code by itself and they don't occur till years later.
Cross drilling a crankshaft would be a hole straight through each main journal. If not, it's not cross drilled. I didn't think it would be.
Some later L88 crankshafts were cross drilled but GM decided that wasn't such a hot idea after all.
I'll look in an old GM listing to see if a code "P" is shown. I don't have truck codes though. I bet John Hinckley is correct (post #2) that it's a truck code.
I had a friend once showed me a book, probably 6 or 7 inches thick, must have weighed 10 pounds. He said it had every code number chevy ever had in it. Does the lime book cover all that?
I don't know why you don't want to listen to John's answer. The engine was indeed installed in a Series 6000 truck. It was called a Taskmaster. That information comes from an August '57 TSB with full descriptions of '58 unit serial numbers.
That same motor with the same engine code can be found in half a dozen other vehicles in the same year. In just trying to get a confirmed answer on p suffixfor that year
Thanks everyone for their help, I found the visual confirmation I needed through the lime book PDF. Sorry if seem a little hard headed but I've been fooled before by well meaning people just trying to help. but everyone here seems to be on top of their facts and again, thanks
You have access to a lot of good people and information here.
The P engine code was used as follows:
1957-1961, 283, 160hp, 2bbl, manual trans, in a truck.
