suffix code
Old Feb 18, 2018 | 12:23 PM
1smokey joe's Avatar
1smokey joe
Cruising
Default suffix code
Need help deciphering stamp code on 1958 739 block stamp is as follows- FI23P. Thanks for any help
Popular Reply
Feb 21, 2018, 01:58 AM
emccomas's Avatar
emccomas
OK, here is a pdf of the latest version of the Lime Book.
Enjoy...
File Type: pdf
Old Feb 18, 2018 | 03:22 PM
JohnZ's Avatar
JohnZ
1958 Flint 283/160hp 2-barrel manual transmission truck engine, built January 23.
Old Feb 18, 2018 | 04:30 PM
1smokey joe
Cruising
Default suffix code
​​​​​​​it also has steel crank hardened and cross drilled with twin tower heads. To hear its a 22bbl truck motor is to say the least disappointing. Can you tell me where that info came from?QUOTE=JohnZ;1596619345]1958 Flint 283/160hp 2-barrel manual transmission truck engine, built January 23. [/QUOTE]
Old Feb 19, 2018 | 11:23 AM
JohnZ's Avatar
JohnZ
[/QUOTE]
From the "Lime Book", the most authoritative source I'm aware of for decoding Chevrolet V-8 identification markings.
Old Feb 19, 2018 | 02:10 PM
GUSTO14's Avatar
GUSTO14
From the "Lime Book", the most authoritative source I'm aware of for decoding Chevrolet V-8 identification markings. [/QUOTE]
John, what is this Lime Book you speak of?
GUSTO
Old Feb 19, 2018 | 02:18 PM
csherman's Avatar
csherman
2026 Corvette of the Year Winner - Unmodified
2025 C1 of the Year - Unmodified Winner
2019 C1 of Year Finalist (stock)
2018 C1 of Year Finalist
NCRS book -
Old Feb 19, 2018 | 05:03 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
GUSTO[/QUOTE]
Old Feb 19, 2018 | 05:09 PM
GUSTO14's Avatar
GUSTO14
Thanks Keith...
I guess the next question is, where can you get a copy?
GUSTO
Ah... I see said the blind man, to the deaf man...
https://www.ncrs.org/shop/index.php?...roducts_id=383
Old Feb 19, 2018 | 05:17 PM
Nowhere Man
Thanks Keith...
GUSTO
that was written by our own member jv04. you can try and PM him as well
Old Feb 21, 2018 | 12:29 AM
emccomas's Avatar
emccomas
The Lime Book, and the associated Lemon Book, have both been out of print for a while.
I keep telling myself that I will resume printing one day, but that day never seems to come.
Stay tuned...I have another idea.
Old Feb 21, 2018 | 01:58 AM
emccomas's Avatar
emccomas
Enjoy...
File Type: pdf
Old Feb 21, 2018 | 11:18 AM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
Wow. Darned nice of you to post that PDF for all the see!
Old Feb 21, 2018 | 01:39 PM
smacota1's Avatar
smacota1
Ditto!!!
Old Feb 21, 2018 | 01:57 PM
Velox's Avatar
Velox
Enjoy...
Thank you very much
Old Feb 21, 2018 | 02:26 PM
1smokey joe
Cruising
Entire engine code is 3737739, date code is A178, has a steel nitrided and crossdrilled crank #3735236 , and x58 twin tower heads. I can't believe it started life as a 2 bbl
Old Feb 21, 2018 | 03:11 PM
emccomas's Avatar
emccomas
That engine got those heavy duty parts because it was a big truck engine. Not your basic pickup truck engine.
Old Feb 21, 2018 | 03:34 PM
1smokey joe
Cruising
They didn't use x58 heads on 2 bbl vehicles and I still can't find a "P" suffix.also the 739 code used on trucks is not the 3737739 code. So much for just using last three digits.
To suffix code
Old Feb 21, 2018 | 03:37 PM
GUSTO14's Avatar
GUSTO14
A good friend bought a nice '59 over 20 years ago. It had a 400 small block in it at the time and ran extremely well. Shortly after buying it, he decided to remove the 400 and replace it with a correct 283. It took him over 6 months to find a 283 block that was suitable for rebuilding even back then. He actually bought 3 blocks before finding one that was worth rebuilding.
I personally would much prefer a 283 from a truck suitable for rebuilding over one that needs major machine work or even resleeving. Needless to say, good 283's are becoming very scarce.
Good luck... GUSTO
Old Feb 21, 2018 | 03:41 PM
Critter1's Avatar
Critter1
I think all small block crankshafts of the era were forged and received one of two surface hardening treatments. Nitride or tuftried.
Are you sure the mains are cross drilled? Is the hole straight through each main journal?
Old Feb 21, 2018 | 04:21 PM
1smokey joe
Cruising
No, not straight through and as i recall not every main. Curiouser and Curiouser? And again on the suffix "P", I can't find a p code by itself and they don't occur till years later.
