[C2] 65 engine stamp question
https://austin.craigslist.org/cto/d/...498167431.html
https://www.corvetteforum.com/forums...tin-texas.html
It MAY be a correct engine for a 1966 passenger car.
Definitely not a Corvette engine.
Heads 3782461 (double hump) A266 (Jan 26, 1966), 62 cc, 1.94 intake, 1.50 exhaust
Block F020IHCH Flint, Feb 01, power glide, Holley carb - used in Corvette and HP cars, but no VIN stamp on the block 3858174 date code A266 (Jan 26, 1966)
As there is no VIN, I know it is not a Corvette motor. Could be a 67 Impala, Chevelle, or Camaro but I thought they stamped all HP motors with the VIN in this era of the early 60s.
Wondering if they only stamped VIN numbers on HP motors with 4 speed transmissions?
Birdcage problems.
Also the cast date on the block is sept 3rd of 65 same as the HAH
Engine suffix.......it's a 65 327/275hp.
Car was inspected by a forum member.
Both frame rails are bad also.
That edict may have carried on past '64 but '64 is where my research stops.
Verne
Verne
Having said that, I do not recall ever seeing a 1967 engine that did not have a VIN derivative on it.
The farm equipment manufacturers used the International and Chevrolet small blocks in motorized farm equipment for many years.
This SBC has almost no cylinder wear nor ring ridge and the valves and guides appear almost new so I am sure it had very few hours on it.
Old farm equipment bone yards might be the perfect source for a near perfect non-VIN stamped SBC when you are restoring the C1 and C2 era cars. They may have even used BBC engines on larger combines.
In the early days, before 1963 or so, the only stamping on the pad was the engine code stamping applied at the engine plant. This stamping showed the date of assembly and a 2 or 3 character engine code that specifically defined the engine build. Any change to what the engine factory installed in the engine (distributor, carb, water pump, etc.) resulted in the creation of a new engine code.
Starting around 1963, a VIN stamping was added to all Corvette engines. The VIN stamping was made at the Corvette assembly factory after the engine was installed in a car on the production line. So, compared to the engine stamping applied at the engine plant, the VIN stamping was done on a different day, in a different plant, by a different person.
I'm not certain, but I think the VIN stamping had something to do with tracing parts from stolen cars.
During the 1960s, VIN stamps were selectively added to certain "high value" passenger car engines, but not all passenger car engines.
I have a 1964 327 block from an Impala that has a vin stamp, and the engine plant stamping indicates it was a high performance engine. I also have a 1967 327 block from a low performance Camaro that had a 2-barrel carb and a Powerglide transmission. That block has no VIN stamp.
My guess is that the engine shown by the OP started life as a low power 327 that had an engine code but no VIN stamp. At some point someone decided to add the VIN stamping that now appears on the pad. The engine code stamp should be sufficient to determine what sort of car the engine originally came from, but the three letter code shows it was not a Corvette.
different person.
