How tight should the bushing fit on the input shaft? Recently had transmission rebuilt and when test fitting the new (and old) pilot bushing on the input shaft, i need to slightly tap them on. To get them off, slightly tap.
I purchased another one and They all measure the same ID.
Do not install fitting tight as it as. It will heat up before it wears in.use emery cloth and see if you can expand the hole in the brass bushing.
I just replaced mine with a napa bushing made in USA and it slides on
easily.
Fred
easily.
Fred
Attacking the bushing inner bore with emery cloth will close up the Oiliite oil pores and entrap abrasive media as well. Not recommended.
C1 of Year Finalist (appearance mods) 2019
I would try polishing the input shaft end before messing with the bearing. Dress it with fine emery cloth and then wipe it with brake fluid or lacquer thinner after. If that bearing is an import I wouldn't be surprised.....nothing fits right from offshore manufacturing.
Yes, it should slip on easily but with no play.
The bushing should be a press fit into the crank. The clearance to the input shaft can not be measured accurately until the bushing is driven into the crank because once this is done, the ID will tighten by a couple thou.
Interference fit to the crank is around 2-4 thousands (0.002 to 0.004 inch). Bushing will compress a bit from this installation......but to a slightly lesser degree.
This is why a "dummy" input shaft is a good idea: both to install bushing and to make certain it is a loose fit after installation.
My old records show input shaft nose diameter is 0.590 inch and bushing ID is 0.592-.593 inch.
Autogear (CF Vendor) makes a VERY NICE Oilite bushing. Even custom sizes. Give them a call.
Larry
