Barn Find L89
Old Mar 13, 2018 | 05:57 PM
maxphunn's Avatar
maxphunn
I went to the Haggerty website, pulled up the valuation tool, search by vin, and entered the serial number for my '59. The results did show my engine HP. BUT, italso listed all the other possible engine options.
Old Mar 13, 2018 | 06:10 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Originally Posted by 63Corvette
I learn something every day....I woulda sworn you couldn't get a W-block (348/409) into a midyear with a can opener and torch.
Why not?
People put 409 motors in C1s back in the day.
Externally it isn't really any different than a MkIV. Exh manifolds would be my concern.
Doug
Old Mar 13, 2018 | 06:16 PM
Boyan's Avatar
Boyan
Default 409
I like it, nice find with any engine!
Old Mar 13, 2018 | 07:32 PM
Westlotorn's Avatar
Westlotorn
Very nice find, people are excited to find a car like that with no engine at all.
Yours happens to have a 348 or 409 in it. Those were never factory in a Corvette but they are classic engines and you can run it as is or sell the engine and take it back to a stock type engine. If it is a 409 they have value for sure if it is salvagable. They also made a ton of torque and would be interesting to have as a talking point.
A small block can be built for very little money and dropped in if you wish to be closer to original. Get the Vin from your glove box and start tracing the cars roots.
Again, nice find. If you got it really cheap, don't tell us, I hate to cry.
Old Mar 13, 2018 | 08:01 PM
R66's Avatar
R66
Welcome to the forum, great find.
You have noticed some cannot believe the used cars of the 60s and 70s were bubba'd with the swap of a small block 327 to a 348 or 409.
Well, having lived thru a good portion of that century, A 67 with a blown 327 / 300 hp (guessing about the original engine) could 'cheaply' be up graded with the 62 409 from a grain truck for the price of $100 or less while a 396 or 427 were in high demand and would bring $175 or more from the junk yard. At a buck an hour wage, $75 was a lot of money.
Given all of us were not born with the silver spoon in our mouth or anus, some rodders had to buy what they could afford, not what momma and daddy could afford.
Welcome to the world of NON PROPERLY RESTORED NCRS CORVETTE OWNERS club. Just here for fun.
Old Mar 13, 2018 | 08:09 PM
KingRat's Avatar
KingRat
it was a 327/350 or 427/390/400 by the tach. so any dreams of solid lifters are gone. and by the small block hood I would lean towards 327/350 but that really doesn't matter since the born with block is gone. the wire holding the radiator is a nice touch too
Can check for the rear sway bar and see what the rear axle code is to further confirm. But, I'm betting it is an L79- it has the 60 psi oil gauge.
Old Mar 13, 2018 | 08:13 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
the same cluster was used for the 327/350 and 427/390/400 that means the oil gauge. but a pic showing if there is or was a rear bar would help
Old Mar 13, 2018 | 08:21 PM
Mosport's Avatar
Mosport
Back in the late 60's a friend of mine put a buile 409 in his 62 Corvette. He welded up his headers out of schedule 40 pipe.
Old Mar 13, 2018 | 08:41 PM
mgsabrsula's Avatar
mgsabrsula
Here is a picture of the dash in my car. It is a 400 hp '67.
Old Mar 13, 2018 | 09:01 PM
Shift_Happens's Avatar
Shift_Happens
Originally Posted by GUSTO14
If it is a 409 (and not a 348), throw a set of the new Edlebrock aluminum heads on it with a good cam and a Holley and it will give most Big Blocks of the era a run for the money.
While clearly not the original engine, if the frame and birdcage are solid it will make an excellent project car, and a unique period piece from the 60's.
Good luck and welcome to the Corvette Forum!
GUSTO
Isnt the dipstick the tell tale between the 348 and the 409? Drivers side is 348 and passenger side is 409? Or maybe vice-versa....
Old Mar 13, 2018 | 09:30 PM
GUSTO14's Avatar
GUSTO14
Correct, dip stick is located on the passenger side for the 409... but also on the passenger side for 348 truck pan. Go figure...
Good luck... GUSTO
Old Mar 13, 2018 | 09:38 PM
Nowhere Man
Good luck... GUSTO
Since I know nothing about 348/409 blocks what oil pan would you use on a mid year. A standard 396/427 pan won’t work will it?
Old Mar 13, 2018 | 09:49 PM
  #33
gbvette62's Avatar
gbvette62
Good luck... GUSTO
Yes, 409 has the dipstick on the passenger side, 348 is on the driver's side. Since the dipstick is in the pan, not the block, a 348 can be made to look like an 409, by just changing the pan.
Old Mar 13, 2018 | 09:52 PM
  #34
GUSTO14's Avatar
GUSTO14
A Stef's pan?
Honestly I have no idea, never really been much of a 409 fan. Although my Uncle bought an SS 409 Impala new in '63 and kept it for about 30 years. It always seemed that the big problem for them was the limited head options. It was quickly replaced by the 396/427 and most R&D ended then. Now of course Edlebrock offers a set of Performer 409 heads. They are designed for use with 1961-65 Chevy W Series 348 and 409 big block engines.
GUSTO
Old Mar 13, 2018 | 09:56 PM
  #35
KingRat's Avatar
KingRat
Correct. I guess I was more focusing on your solid lifter comment and that it probably does not have a rear sway bar. BUT, could it be the original radiator?
Old Mar 13, 2018 | 10:13 PM
  #36
gbvette62's Avatar
gbvette62
Good question, and no, a 396/427 pan won't work on a W motor block.
The 61-64 409's used a 6 quart pan (6 quart system, 5 quart pan and 1 quart in the filter), while the 348's used a 5 quart pan (4 qt pan & 1 qt in filter).
I'm guessing the 348's smaller pan, might be easier to fit, but can't say for sure. Years ago, I knew someone who had a 409 in a 65 Chevelle. He had to modify the pan's sump quite a bit, to fit the 409 in the Chevelle. With the way the engine is set back in the Corvette frame, a 409 pan might not need a lot of modification, to fit in a Corvette frame?
Old Mar 13, 2018 | 10:34 PM
  #37
GUSTO14's Avatar
GUSTO14
The pans will interchange, but the 348 pan will need to be clearance'd to clear the counterweights of the 409 crank. The 409 pan will work fine on the 348 engine.
Good luck... GUSTO
To Barn Find L89
Old Mar 13, 2018 | 10:51 PM
  #38
jackal396's Avatar
jackal396
C1 of Year Finalist (track prepared) 2019
2015 C1 of the Year Finalist
Great find and thanks for posting, always like the finds that come out of the barns.
jp
Old Mar 14, 2018 | 12:02 AM
  #39
LowKat's Avatar
LowKat
2018 C1 of Year Finalist
Cool find. I like W-motors.
Old Mar 14, 2018 | 12:18 AM
  #40
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
Welcome to the best damn old corvette forum there is!
Gee I wonder if he changed springs on the front end to handle that boat anchor? .....just kidding, great motor but a tad an the heavy side, which, if I remember right was the reason GM dropped that W design in favour for the newer big block.
I'd leave it in there, get it road ready and freak people out at show/shines.
What ever the case I'd love to hear about the chase. Where did you hear about it and how did it proceed, ending up in your hands?
