Battery Recommendations
Old Mar 18, 2018 | 09:34 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Originally Posted by MikeM
The clock is not a constant drain. It is a drain only when the points close to engergize the solenoids. I don't know how many "clicks" is would take to drain a battery but I suspect it would be many thousands.
Wow ... who knew
Old Mar 18, 2018 | 10:00 AM
SWCDuke's Avatar
SWCDuke
Most "brand" batteries are made by Johnson Controls and just have different stick on labels. Walmart probably has the best prices for the Group 24 you need. Peel off the labels and you have a plain, black, unobtrusive battery.
I have one that's 16 years old... killed it twice, and it's still going strong.
Duke
Old Mar 18, 2018 | 10:14 AM
MikeM's Avatar
MikeM
The "cheap" Walmart batteries are three bucks more than Rural King made by Exide with the same warranty. Most WM batteries are at least twice that price. Or triple.
I don't believe you have a "cheapy" WalMart as they have been on the market only a couple of years. Around here, anyway. But batteries were a lot cheaper 16 years ago than they are now at WalMart and elsewhere.
Old Mar 18, 2018 | 02:02 PM
toddalin's Avatar
toddalin
"Many thousands" is easy to do when the car sits for 6 months or more at a time.
I also use the green disconnect switch and on the few occasions when the Optima went dead is when I failed to disconnect it. I usually let the car cool before doing that.
As some have said, Optimas may not be what they used to be, but mine has been great.
Old Mar 18, 2018 | 05:16 PM
MikeM's Avatar
MikeM
It is recommended to charge the battery on a car that has sat idle every month whether it has a clock winder or not Even if you use a disconnect.
I believe a better choice than a disconnect would be a battery maintainer.
Old Mar 18, 2018 | 07:33 PM
toddalin's Avatar
toddalin
Deep cycle batteries, like the Yellow Top, don't need charging every month and can be left disconnected for long periods without consequence.
Old Mar 18, 2018 | 07:52 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
the guy drives it enough to keep battery up.
he hasn't addressed why he needs a battery.
Old Mar 18, 2018 | 08:09 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
then Mike what am I doing wrong in my Chevelle with a battery I bought in 2009. the first six years it sat in my dads garage that never got below 50* and two of those years I used a battery tender in the winter for a max of four months. then I moved the car to my garage thats not insulated and I leave it sit for four months. I do use a cut off switch. and last week I started up my car after sitting and it cranked right up
Old Mar 19, 2018 | 03:46 AM
babbah's Avatar
babbah
Odyssey - Simply the best! 10+ year service -
Old Mar 19, 2018 | 08:04 AM
MikeM's Avatar
MikeM
Can't tell you what you are doing right or wrong. I don't use a cut off switch on anything. I've used a battery maintainer on a few batteries and it does seem to make the battery last longer. I don't recharge every month. If one of mine sits for 6-8 months without being run, I'll put a charger on it, just in case as I don't like to crank on a discharged battery, even if it will crank over. The recommendation to charge the battery every month is from the "experts". I'm not an expert, just a very experienced battery user.
My comment was directed at the statement that the clock is a continuous drain on the battery. It isn't.
Cutoff switches are great if there's something wrong with your car.
Old Mar 19, 2018 | 09:04 AM
Duck916's Avatar
Duck916
I've got a Duralast in the car that performs well, even after it was completely drained a few times while I chased a parasitic current draw. Now, the car can sit for a month and it still starts right up (and that's with a quartz clock running).
Old Mar 19, 2018 | 12:36 PM
ejboyd5's Avatar
ejboyd5
In addition to eliminating parasitic drain, cut off switches are the first line of defense against short circuits and fires caused by animals gnawing the wires in unattended vehicles.
Old Mar 19, 2018 | 03:18 PM
  #33
Grampy's Avatar
Grampy
Good info. With JCPenny on life support I may actually have to shop around and pay for a battery for the first time since 1976 when the current one dies.
Old Mar 27, 2018 | 05:27 PM
  #34
MikeM's Avatar
MikeM
If that's all you want.......................
Why pay way more?
Old Mar 27, 2018 | 05:28 PM
  #35
Nowhere Man
Originally Posted by CorvetteMikeB
Any luck finding a new battery? Did you get a NCRS original 1965 style battery? I am going full Restro-Mod with my car in the shop with new electronic A/C and FULL power. I will need a strong good battery in the near future. Thinking Sears Die Hard or AC Delco for my ride. Not doing NCRS for $300+ just want it to be black in color.
Do you over think on this subject when you buy a battery for your daily drivers. What’s so special about all you do-dads vs all the millions of new cars on the road with way more electrical draws
Old Mar 27, 2018 | 11:21 PM
  #36
redstar's Avatar
redstar
From: Kingston, TN, Denham Springs, LA & Agoura Hills CA
[QUOTE=babbah;1596811972]Odyssey - Simply the best! 10+ year service - [/QU
In the early nineties used 14 HD Odyssey in series to test the prototype contactors/power relays for the international space station. These batteries were the best. We built 3 sets of 14 batteries and never had any failures. Of course, some of the early relay prototypes failed during hot switch testing.
For a battery dead-face contactor I would recommend a Bubba relay from kilovac. It had a contact resistance of 80 micro-ohms. Translates to about 60 millivolt drop across the contact when starting your engine.
Old Apr 21, 2018 | 10:49 PM
  #37
CorvetteMikeB's Avatar
CorvetteMikeB
Originally Posted by hikerneil
I have a 1965 with an OEM 327 / 300, and I drive the car an average of one time per week (during the winter) and probably 2-3 times per week in the summer. The car sits in a warm garage in sunny Southern California year round and never goes near cold weather. I have no A/C in the car.
My battery is dead and I need a new one. Based on above, is there any clear cut leader for a replacement battery? I am not trying to score NCRS rating points.
Thanks.
If your still looking for a car battery Menards has AC/Delco brand for sale at just $100.
Old May 1, 2018 | 12:37 PM
  #38
CorvetteMikeB
I have a Delco battery that is going on nine years that doesn’t use a battery tender and cold winters
Do you know the model number of your C2 Corvette A/C Delco Battery?
