Brake light switch
Old Mar 19, 2018 | 10:34 AM
Skydude66's Avatar
Skydude66
Default Brake light switch
No brake lights on my 66' with A/C. Checked bulbs and fuse so looking at the switch. Wondering if there is a way to check the switch without removing and replacing it? The A/C vent is directly below the switch so looks like what could have been an easy job might not be so easy.
Bob
Old Mar 19, 2018 | 10:45 AM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Check the ground wires on the tail light housings. Dennis
Old Mar 19, 2018 | 10:52 AM
SoCalErv's Avatar
SoCalErv
Army
Bob
Place a test light on the two wires removed from the switch, if good the light will come on. Now place the connectors back on with the test light still attached. Press the brake pedal down, if good the test light will come on.
Old Mar 19, 2018 | 11:16 AM
Joe Inama's Avatar
Joe Inama
Default Switch
Bob
Run a wire between both wires to pedal switch, brake should lite up. If no chase ground.
Old Mar 19, 2018 | 11:48 AM
Skydude66's Avatar
Skydude66
Thanks for the help. I did run a wire and the brake lights came on, so looking for a replacement switch.
Old Mar 19, 2018 | 11:58 AM
409/409's Avatar
409/409
Squirt wd40 in the plunger and push it in and out a few times. It worked for me. If not the switch is about $14.00 at O'Reillys.
Old Mar 19, 2018 | 12:12 PM
Joe Inama's Avatar
Joe Inama
Default Switch
Just bought one at Oriellys
Old Mar 19, 2018 | 12:16 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
It takes less then five mins to remove the ac parts to get to it.
Old Mar 19, 2018 | 12:26 PM
409/409's Avatar
409/409
Try my method. If it works take the new one back for a refund.
Old Mar 19, 2018 | 01:22 PM
Skydude66's Avatar
Skydude66
What part # ?
Old Mar 19, 2018 | 05:02 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
I've managed to snag a spare metal brake light switch...those plastic, toy ones just don't impress me...
To Brake light switch
