Octane Solution
Excessive detonation and lack of ZDDP in the oil...
You've found about at the first -- and any CI-4 rated oil addresses the second...
Because the octane rating was dropping then, along with compression, I became concerned about detonation. However it was difficult to hear the engine over the sound of the exhaust on that Sportster.
I was also flying reciprocating airplanes at that time while attending flight training. In order to hear our radios over the sound of the large radial engine right in front of us, we wore ear plugs under our helmets. I decided to wear them under my motorcycle helmet and noticed the ear plugs muffled the exhaust enough that I could now hear the engine. I added some octane boost and noticed immediately that the engine ran even quieter. I have continued to wear earplugs under my helmet while riding to this day.
One other thing I noticed many years ago (in the early 80's), was that when leaving the drive through of a fast food restaurant with the window down, I happened to notice our carbureted Honda seemed to be pinging a bit. It was summer and the A/C was on, so I turned it off and drove through again to see if there was a difference. Sure enough the pinging was gone. Something about the close proximity to the wall of the building (and the window being down) amplified the engine noise that I had not otherwise noticed. A slight tweak of the timing seemed to eliminate the problem.
I believe that the widespread use of electronic fuel management and knock sensors has pretty much eliminated this as an issue on most modern cars, but techniques such as this may prove useful in diagnosing our older classics.
Good luck... GUSTO
Search for threads started by me and download and study the tuning seminar pdf for a more thorough discussion.
Also measure head gasket thickness at the corners of the head-block interface. Chances are it will be much thicker than the OE .018"steel shim gasket.
Start with the highest octane available, then let the tank get close to empty and add about three gallons of 87. Then test for detonation by loading up the engine at low revs, like half throttle or more at 1500 in top gear, especially going up a mild grade.
If no detonation run the test again, or if it does detonate run the test with mid-grade. Over the years most OE engines have been rebuilt with lower compression than OE, so I figure you have at least a 50/50 chance of being able to run detonation free on 87 or 89 even with a more aggressive than OE spark advance map.
Duke
There is a forum 'sticky' thread at the top of the web page somewhere that discusses this in detail... Here it is:
https://www.corvetteforum.com/forums...in-please.html
Don't want to hijack the thread but, as a new owner, this is critical info...
To the OP - along with downloading the tuning seminar download and read my oil article, and I think many others may need a refresher on this subject, too.
Duke
Duke
This chart shows typical levels in the Mobil One product line.
I use the 15W-50W (red rectangle) product....some say I'm foolish for spending the money for synthetic...some say not.
My annual oil change in one classic car is hardly breaking the bank and NAPA has this oil on the shelf...
Camshafts are hardened 3/8 of an inch deep on the nose. All lobes are hardened the same. That is why re ground cams were possible. It is not a surface hardening.
Lifters did change and that probably contributed. Remember the old days GM lifters had the hard plate, the last 1/8 inch that touched the cam lobe was different material.
Sealed Power Lifters had the ping mark where they were all tested for hardness prior to sell. That was the old days and in 1970 you paid more for those lifters than you pay today 40+ years later. The oil used today is more important to protect your cam and lifters. I still run Rotella or Delo Diesel oil 15-40W and it has worked so far.
Detonation, if you jab the gas and the engine starts to wind up and then feels like it is dragging a heavy load and the sound of the exhaust kind of goes flat. That could be heavy detonation. Get out of the throttle and hope no damage was done.
This type is silent except for the exhaust note change.
Pinging although bad is not nearly as dangerous as heavy detonation.
Had a 1961 that was my daily driver back in 1971, but a pig for originality (paid $750 for the car and $1500 for a hardtop). But, back then all gas was higher octane and at $.27 a gallon I bought Premium (Ethel for you old timers). But, I'm 69 now and this is the 1st classic I've had since 1979. Since this is a bucket dream toy, that will be driven on a very limited basis, I'm hoping the lack of creature comforts isn't too bad.
I'll post photos when I get it. Front seats being rebuilt and upholstered right now, rest of the car looks fantastic.
Butch
