[C2] Antenna cable replacement
Hello members - AM located in the Phoenix Az area. I have a 66 Roadster. Trying to straighten out the power antenna. Have a new motor ready to install, but also need to replace the antenna cable. Anyone replaced this cable? Is it held inplace under the carpet by clips? Will splicing the new cable to the old and pulling it through work??
Thank you in advance for your help with this!
jpjs
jpjs
It obviously runs from the radio over to the driver side, under a metal plate that can be pryed up, then under the insulation along the rear wheel well hump. Then it goes through a grommet along with other wires then to the antenna. You will need to be careful getting the cable through the grommet.
Dennis
Dennis
2015 C2 of Year Finalist
it might be easier if you gently pull back the carpet on the wheel well to get to the cable. It might be glued down
Dennis
Dennisjpjs
Pull the carpet on the side beside the driver seat. The plate might be covered with the jute padding or some other insulation. Just follow the cable.
Dennis
It was purchased new in Alaska
You may want to check the grommet where the wires pass through the body in the back. Mine was as hard as a hockey puck. Having it on hand may save you some time. Jerry
Joe
Though this is for our '65 AC coupe, there might be some useful info in the attached PDF regarding the carpet support and clips if your car has it on the driver side. Slitting the grommet will allow for a fairly easy install of the rear harness and antenna cable. A little Sil-Glyde (NAPA) on the grommet can ease the install into the rear bulkhead as well.
Dave Z
Dave Z
