Cranking Compression
AC 44 or NGK XR4 plugs
Heat riser to be wired wide open
Check Meter blocks/float bowl's for warpage
Blue and black gaskets on the carb rebuild
No Hardened Valve Seats if it comes to head work
Re-run Vacuum test with engine warm and idle adjusted to spec.
Just got the assembly manual in the mail today, have the 66-82 Vette shop manual and the Chassis manual is on the way.
Will not have results to post until later Friday.
We (I) learned this lesson back in 1966 and no reason to repeat it today. However, the fact that today's gas is unleaded should help the AC 44 to live on the street better.
Still, I run AC 45 today in my car and have for 52 years.
FWIW.
Larry
But AC 45, R45 or R45S will serve you best if you have a relatively stock and street driven small block car. And the R plugs are available and cheap.
FWIW.
(Maybe nothing).
Larry
FWIW.
(Maybe nothing).
Larry
Now plan to do the vacuum, compression and leak down tomorrow. Have only a half day today so I am working on installing the new directional switch in the column.
After years of using them in a C1 and C2 I find them superior to any other plug I've used including the much-touted AC/Delco series and the Autolite 86 replacements...
With the lead out of gasoline, I quickly found out my points fired ignitions and a carburetor would allow plugs to run at least 40K miles.
I recommend the B4, which is not resistor, plain center electrode plug that is essentially identical to the old out-of-production AC 45.
Another good plug is the Denso W14-U... same heat range, non-resistor and it has the Denso "U-groove" ground electrode.
The NGK V-power notched center electrode and Denso U-groove are good features because the spark likes to initiate and propagate from sharp edges. That's why old plain electrode plugs show a rounded center electrode after several tens of thousands of miles of service.
If you insist on "AC" plugs then the R45 is best for normal driving (small blocks) and R45XLS for big blocks.
Duke
It was true back when gasoline contained lead and new plugs didn't stay clean for very long. But that was decades ago.
I've had the same set of correct AC 43N plugs in my 66 425 HP 427 car for about 15 years now and they don't miss a beat. Same for one of my FI 63's with AC 44's.
If spark plugs don't survive for more than a few hundred miles using lead free fuel, the engine is either huffing oil or running too rich.
Old myths never die.
This is a fairly wide range, and I prefer to use the hottest plug that doesn't get into the preignition range since they tend to burn off deposits faster and don't build up permanent deposits as fast, which means longer service life.
If the plug does get hot enough to get into the preignition region deposits will melt and form a glaze on the insulator, which is nearly impossible to remove and is visually obvious.
TI/HEI systems can get away with colder plugs because they have about double the per spark ignition energy of the single point system, so they will fire a plug that has wider gaps and more shunt resistance deposit buildup.
Duke
You guys are probably right and the colder plugs will last. But so will the the hotter 45 series and I can't see a downside at this point for street driven cars.
I currently run a 50/50 mix of non-ethanol and leaded 110 octane race gas in my 1967..............and the 45 plugs work very very well. I still have about a dozen boxes of AC 44 on the shelf along with the same amount of AC 45. Although I tried, I went thru two sets of 44 when I used them from awhile back (in the early 1990's). The 45 plugs are still in since that time.
I should be ashamed, right.......not changing these in all that time
Now we can also debate my expensive taste of using non-ethanol/leaded race gas in the car, but it really does run better with that mix. And for the miles I put on it each year, the cost to me is nil. It's just a hobby.
I enjoy and learn from your experience with these cars, but some of us have also spent time with these cars since new.
Larry
But, tell me, back in the "good old days" did a hotter heat range burn off lead deposits?
I always thought that a hotter plug would burn off carbon faster than a colder plug would. But, then again, I'm not a Corvette Historian, just a simple Engineer/Mechanic who has been fixing cars for the last 55 years, so, WTF do I know.
GM did find that seat recession could be an issue with unleaded fuel back in the seventies, but only in truck engines that operate at high sustained load. In normal road driving Corvette engine loads are much lower, so seats and valve run much cooler.
GM did start induction hardening exhaust valve seats and installing rotators in the seventies, but I don't recall ever hearing of excessive valve seat recession on an old Corvette, whether a fairly recent rebuild or an old original never rebuilt engine.
It's a tradeoff, and there's a vast amount of anecdotal evidence that indicate the risk of seat inserts outweighs any possible benefits.
The lead oxide coating that forms on the valve seats does appear to provide seat protection, though I don't think the mechanism if fully understood. This coating is very long lived once it reaches a steady state, so my advice to those who are concerned is to run some leaded fuel in the first couple of tanks after an engine rebuild, and if it continues to be a concern, repeat it every few thousand miles.
Duke
Duke
And, I can attest to having had to scrap a head because the seats were into the water jacket.
The culprit is known as "core shift", where olde fashionede manufacturing processes and fixturing led to wide variations in how a core pattern was suspended within the casting pattern as a whole. Short of it is...........some heads are safe to convert to hardened exhaust seats and some aren't.
In my case, two identical 461 castings: one head was OK and the other one had all 4 exhaust seats into water. The leak was very slow and finally caused the head to crack. Once the crack was fixed, I had that head pressure tested, and that revealed the underlying problem. I had the seats installed long before I became aware of the riskiness. I never would have had it done had I known.
Reopen after review
Members:
For the second time today, I’ve had to close and clean a thread due to personal bickering among members, in some cases the same individuals. Unlike the last thread, I simply deleted full posts which included useful information because it’s not worth editing out all the personal namecalling, personal commentary about people and other BS.
I’m going to reopen this thread rather than close it, if people want to restore lost information or continue the technical discussion.
Multiple members had posts removed and were sanctioned at various levels. This is a reminder not to engage in personal hostility and conflict, no matter who starts it. If you cannot attack ideas rather than fellow members, try a different thread.
The seats that broke into water are 7/32" thick.
Wasn't this thread about cranking compression?
