C2 Barn Find
Had some other projects, requirements come up that took away my "ol blue" time so just a quick update. I got the bad wheel stud replaced and the parking brake fixed and back together. Now here is an idea for someone to become a rich person. Invent a parking brake that works off of the caliper like the GM single piston design with the lever, I know I would buy one and probably so would anyone else that has ever worked on the e brake in rotor hat assembly by GM. Not a lot of fun to be had there. Anyhow, on a brighter note I got wheels and tires for ol blue. American Racing TTII one piece 16x7. Yeah I know, everybody and their brother runs them (yawn) but I like them and a friend took them off of his car going for a new look so I got a deal on them. They had tires but the rears were 235 so to wide, and the front are 205 (60 series) a bit smaller than I would like. But I kept the 205 on the front and bought some matching 215 for the rear. I had some old style (metal not plastic) three prong knock offs that I really like, but looking at them on the wheels they seem to stick out kinda far, at least to me, so not sure I'm going to keep them yet. Well at least she is back on the ground and all done underneath, except for mufflers, unless something else unexpected pops up. With any luck at all I can get a test fire and cam shaft break in this week so I think I am seeing a light at the end of the tunnel, maybe even a test drive in the near future. Woo Whoo
I got it running with a lawn mower type gas tank strapped to the front fender and the only problem is a slight leak at the fuel pump. Still will have to do some tune work, as I started it with a known good carb, but it is only a 650 cfm unit. I will be putting on a bigger carb later and I also used an HEI that I knew was good. I am going to add a Pertronix to the distributor so I can get my tach back and working as the HEI did not have a tach drive, but again it was a know good distributor as I didn't want any failures going on with the camshaft break in. Now I got a new gas tank as the old one is loaded with rust from sitting 20+ years. I got one with a vent as I plan to add EFI later and will use that for a return. I don't know for sure if there is enough room to add an in tank pump to the top side and I have not had any luck finding one that can go in from the bottom and work upside down. Another person here on the forum said they sent their tank in and had a pump and baffle installed but I am looking at some of the new pumps that have a foam type sock around them and don't require a baffle. Don't know how good these work so I have more research to do in that area. I am still waiting for a new filler neck and boot for the top and a sending unit for the bottom but I think I can add these after the tank is in so that is my next task. I really wanted to get this all done before putting the new mufflers on but am getting anxious to drive it before winter comes. I see the light at the end of the tunnel so maybe I'll just go with a carb for now.
Well I went by the muffler shop on Friday and they said they were really behind and couldn't get to the car for about 10 days. NO WAY. I thought. I'm not waitin 10 days for muffler work. So instead of trying to use the chambered mufflers I already had I ordered 2 "direct fit" Magna Flow and did the install my self. Cut the pipes a couple times till I got them right. Readjusted the head pipes and the intermediate pipes, and then set up the mufflers and tailpipes. Finally got them all adjusted where I wanted them except for the tail pipe tips. No matter how I seem to adjust them they don't come out of the valance holes straight, or point toward the rear correctly at the same time, its like I can get one or the other but not both. l know the brackets move side to side and the hangers on the muffler go up and down but I can not seem to get them where I want them. Anybody got any magical suggestions for getting them to not look so crooked?
Oh yeah, the sound is awesome. About 1/2 way between chambered and turbo. Really like it.
Today Ol Blue made it out of the garage and around the neighborhood under her own power for the 1st time in over 20 years!
Just a short drive to shake down and look for things breaking or falling off.
Happy to report neither occurred. Still some things to work out, no horns, etc but all major systems are go.Thanks to you all for staying with me and the encouragement. Looking forward to a longer test when I check a few more things out.
A couple of the members have asked me about my progress and I apologize for the long lag time, but I had some family issues that got in the way of my projects, but am getting back on track now. I had to put Ol Blue on the back burner for a bit but got back to her in the late summer this year. Couple of big hiccups that came up involved the front suspension and overheating.
So I got involved in rebuilding the front suspension, and thought, I can get tube a frames with new ball joints and bushings for just a bit more cost than rebuilding the stock ones and get some extra caster besides. WRONG I got some (in another thread) from an on line vendor and after putting them on, 1, the car sat up like a 4 wheel drive P/U, 2 there were NO steering stops so the tires hit the fenders and frame, AND not enough room to get the camber needed because of not enough room for shims to get to 0.
Talked with vendor several time and finally gave up
I put in offset cross shafts (which got me close but not to 0 on camber) built my own steering stops, and cut one full coil off of the front springs. I finally got it to sit where I liked the stance but still want 0 camber, so I will probably go to Global West in the future, (which is what I should have done in the first place) Then on to the overheating. I had an aftermarket aluminum radiator and electric fans in the car. (big block with iron heads) and going driving it was ok as long as you kept air moving through it. At each stop light it would creep up a little higher, and never go back down. Soon I was in the red and peeing out of the over flow tube. AND stop and go traffic, well forget it. So I took out the aftermarket aluminum radiator and the electric fans and put in a 7 blade GM Corvette fan, new fan clutch and a Dewitt radiator. Took the temp down about 15 degrees. Still working with it, but it is a lot better. Another question about that, but for another thread.
Took her out to the Golden Super Cruise last weekend (last one of the summer) and car was a bit hit. Seems people like patina on C2, maybe because they don't see many that are not fully restored. Lots of smiles
Currently I am still working on the e brake (cable froze up) w/wipers (appear to be siezed up) and the headlights, which take about 1/2 a day to open. Also need a new headlight switch. Did I mention letting a car sit for 20 years is a really bad idea.
A couple of pictures from today, sorry about the star bursts, I guess the lens was dirty or something. Special effects?
Thanks for all the encouragement from those following the thread, I will try to be more timely in the future.
Keep it up, we love seeing the progress. Heck, I bought a '93 40th a couple of years ago that was supposedly all great, still finding things that need to be redone every time I drive it!
Dennis
