Slipped harmonic balancer
My understanding is the balancer functions by absorbing crank shock during acceleration. My cushion material is likely not doing the job anymore.
Dennis
Joe
Okay you can drive the car with a dampner that has moved or will move but once it starts to slip other parts will start to become damaged until something catistrophic happens - it's your choice. And you can set your idle timing/advance by ear as some owners be!ieve that is best method . Just turn the distributor until you get the smoothest idle but you may need to change the idle RPM and readjust timing again several times to get what you want.
Well your just a Google search from answering your question on what a dampner is for as I'm sure you find a better answer than mine. But my concept is that the dampner counter reacts to the pulses generated by the piston and rids onto the crankshaft.. It is dampner but frequently called a balancer even by some of it's own manufacturer. I don't think it has anything at all to do with harmonics.
But if you still need help most large cities have corvette specialty shops that I'm sure would love a to work on a C2. If not able to find a good shop then contact your nearest corvette club.
I had one take out a fan and radiator. Got lucky and didn't damage the crank.
The shaft was keyed and quite worn that allowed the balancer to rotate back and forth, unbeknownst to me.
One day it rotated and tightened the 3/4" grade 8 bolt so tight that it snapped the head right off the bolt. I could hear the bang way up in the driver's seat!
A new key and an application of loctite shaft and key sealer is holding it in place today.
Just go and replace the balancer.
Now i am not judging what people do. Mainly because the number of Corvettes I get in my shop every few years that when I go and use my timing light. It is useless due to the notch on the outer ring of the balance has spun. So I use a vacuum gauge and get it to where it runs great.
YES..I also use a tool I made as a piston stop to kinda get the number one firing position marked on the balancer. And it does kinda depend on how much movement the flywheel area makes before I can see the distributor begin to move.
But...heck. What are I going to do when someone does not want to put a new balancer on their engine The best I can with what I am given. I had one balancers outer ring that was so loose...it was scraping against the timing chain cover and the owner was fine with it even after it showed it to him.
So..In your particular situation., Like I tell many of my customer show barely put 500 miles of easy driving on their Corvettes. "I guess it will be OK due to I do not have a crystal ball. And in a month or two...who knows what will happen. And if it is easy driving and you are NOW aware of the issue. I leave it up to you due to it is you car and your money and who am I to decide."
So..whatever a person decides is up to them. I know it goes against logic and how many of us think. But I have gotten past that a long time ago. Some of my stories would make your skin crawl.
And lets not confuse doing a butchered repair job versus that of NOT doing a repair that is noticed that a customer does not want to pay for. I do not butcher Corvettes....becasue I have handed keys right back to some people who have safety issues that need repair and they want a cheap sub standard repair.
For what this is worth:
L36 engine is what is he has. Thus his engine is a big block. And being a 1966. I have always seen them with a bolt in the end of the crankshaft. Correct me if I am wrong...but I doubt it.
DUB
