Firewall paint
Old May 31, 2018 | 03:38 PM
ptjsk's Avatar
ptjsk
Default Firewall paint
Looking for suggestions of firewall, and wheel well paint.
I want the original sheen, or as close to as possible.
Thanks,
Pat
Old May 31, 2018 | 04:46 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
I never worried about what is was. I repainted mine with semi-gloss black. Dennis
Old May 31, 2018 | 08:34 PM
Boyan's Avatar
Boyan
Default Paint
Krylon INDUSTRIAL 1613
Old May 31, 2018 | 11:09 PM
mblake101's Avatar
mblake101
Old May 31, 2018 | 11:59 PM
vettebuyer6369's Avatar
vettebuyer6369
Thanks,
Pat
Not sure where you are in your project, Pat, but just a reminder: when I was stripping my undercarriage of incorrect paint and undercoat, I removed a bit of the job number found low on the firewall on the RH side before realizing it was there.
Just in case this matters to you.
Old Jun 1, 2018 | 01:08 AM
ptjsk's Avatar
ptjsk
Thanks Steve,
I was actually hoping to salvage the body numbers, but just really couldn't if I wanted to get it clean.
I did take pictures so I can duplicate them.
Pat
Old Jun 2, 2018 | 08:54 AM
20round's Avatar
20round
C2 of Year Finalist (stock) 2019
Thanks,
Pat
i did mine in SEM hot rod black. it is a satin finish. it looks great..looks too me like a perfect match too the factory..JMHO
it is about a $100 for a kit. and it will cover a lot of area. good luck troy
Old Jun 2, 2018 | 08:57 AM
ptjsk's Avatar
ptjsk
That looks great Troy! Did you do inside your fender wells with that too?
Thanks,
Pat
Old Jun 2, 2018 | 12:50 PM
20round's Avatar
20round
Yes i did my fender wells inside and out. I will have too check for pictures. Thanks troy
Old Jun 3, 2018 | 03:22 PM
vettebuyer6369
Thanks Steve,
Pat
Yeah, when I started stripping and cleaning, the firewall on that side had the job number covered up. When I started to get stuff off, I could see it. Not exactly something I could preserve.
But like you, I have photos showing the "406" and where it goes.
Old Jun 3, 2018 | 08:13 PM
ptjsk's Avatar
ptjsk
That's cool stuff. Does it match all your other locations? Rear bulkhead, both doors?
Pat
To Firewall paint
