Pop,
The only recommendation I can make is to be sure you use an iron cam gear - not steel. The steel will mill the front of the block without a thrust washer behind it and that will require machining the gear so both gears are coplaner.
I would go with Cloyes, they are still a basic manufacturer. Sealed Power buys from Cloyes. For a stock 300 HP the stock timing set would outlast your rings and bearings.
You can buy a true roller and they are better at 4 times the money but for a 300 HP I see no advantage.
I'm not sure where WGuy gets the steel info from but the steel sets have a Torrington bearing which keeps the gear from wearing on the block. I would prefer the steel. I agree with everyone else that the cast should outlast you but the steel sets with the bearing are cheap as well. A cloyes plus roller is a good choice.
Some sets come with the bearing; some sets come with a flat washer. My set came with nothing so I had to buy the washer (even though they call it a bearing). I had to machine .042 from the back of the steel cam gear for the two gears to line up properly. My point was simply not to use steel against the cast iron block.
I would agree with that. I've just never seen a steel gear without the brass shim or a bearing. But there is no length parts sellers will spare to make something cheaper. I'm building a flathead Ford and the guy is buying all good parts, Offenhauser heads and intake forged rods whatever he needs. He orders 3 carbs last week and tells me what a great price they were. They come in and they are a brand well known for selling inferior parts for everything. I don't have it in me to tell him they are junk. We'll cross that bridge when we get to it.
One of the other issues I've noted (at least on W motors) is that the new double roller gears were copied from the truck gears, which have a 5deg retard built into them. It's imperative to degree the cam after installing the new set-up. I had to use the 4deg Adv slot in the crank gear to wind up with a 1deg retarded cam. (which I'm fine with).
The OE truck replacement roller chain is available in two varieties for small blocks. One has a single indexing hole, which indexes the cam at the OE position, and the other, which costs about the same has two additional indexing holes to allow 4 degrees advance or retard.
I agree...basic Cloyes will do fine. I ran $30 Cloyes in my 7500+ rpm big block with a .774" lift solid roller cam and springs that could hold up a house on the street and track for years with absolutely no issues or abnormal wear.
I think the absolute best out there is probably Rollmaster with an IWIS chain included..but that's overkill for this sort of build.
JIM
