carb spacer
Old Jun 14, 2018 | 04:07 PM
number3's Avatar
number3
Default carb spacer
Is anyone using one ? I have a 65 vert 327/365 hp and when i park it all i can smell is gas , no leaks anywhere , but i suspect the gas is boiling from the heat ? any advice ? thanks
Old Jun 14, 2018 | 04:39 PM
Avispa's Avatar
Avispa
May seem like a strange question, but what kind of carb is on it? Holleys are prone to leaks from the fuel bowl(s) because they have gaskets below fuel level and the threads for the bowl screws are prone to stripping. Had to Heli Coil all 8 bowl screw openings in my old 3310 to solve a bad gas smell and hard starting after sitting only 2 or 3 days. The fuel bowls were emptying out. There were stains on the intake manifold but no visible liquid gasoline.
Old Jun 14, 2018 | 05:43 PM
number3's Avatar
number3
yup its a holley maybe time for an edlebrock
Old Jun 15, 2018 | 01:07 PM
MelWff's Avatar
MelWff
did you check the float levels?
do you see gas dripping into the intake after you shut off the engine?
did you check the float bowl screws for looseness?
have you tried a aluminum insulator plate under the carb?
Old Jun 15, 2018 | 02:12 PM
MikeM's Avatar
MikeM
Might be time to fix what's wrong with your Holley. They didn't do that when new.
The worst thing you could do to an OEM Holley on these engines is to let the carburetor dry out for an extended period, let the gasket dry and shrink and then have a ham fisted owner crank down the bowl screws and warp the metering body. Never saw the screws stripped but whoever would tighten the screws enough to do that should own tools.
New gaskets that don't shrink, setting the floats correctly and making sure the metering blocks are flat should take care of the problems like this in most cases.
Old Jun 15, 2018 | 03:08 PM
DAN70's Avatar
DAN70
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
I’ve never have had a hard/hot starting problem. I must be doing something right, it gets pretty hot here in VA. Good tune and good adjustments seems to do the trick for me.
I’m not trying to stir the pot but, I’ve never had to use spacers or special gaskets on any of my cars.
Old Jun 15, 2018 | 03:42 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
you can count me in on that.
Old Jun 15, 2018 | 03:44 PM
GTOguy's Avatar
GTOguy
Using two of them on my '61...one under each carb. Masonite 1/4" thick. They WORK.
Old Jun 15, 2018 | 05:06 PM
6T5RUSH's Avatar
6T5RUSH
Cruise-In III Veteran
Aluminum Shield <br/>
Front bowl temp before shield install
Front bowl temp after shield install
Made a believer out of me.
Jim
In God We Trust!
Old Jun 15, 2018 | 05:36 PM
tubman's Avatar
tubman
You really shouldn't need one for a stock engined car. I have a restored '67 L79, and have nevr had a gas smell problem. When I first finished it, I had a problem with gas stains on the float bowls and manifold. After reading and doing some research, I purchased a "Surface Plate" (a 2" thick piece of 12" X 12" granite with a perfectly smooth polished surface). I used 320 "Wet or Dry"paper on it and made sure the mounting surfaces were perfectly flat. After that, no more stains. I rebuild a few carburetors now and then, and I give every flat surface I can a pass on the surface plate. Most are OK, but occasionally I find a nick or warp. Then it's time for more work to eliminate the imperfections or source a better component..
The guys above that mention float bowls warping and over-tightened screws are on the right track. Holley's are prone to this type of problems. Also, the tip to use the new better gaskets is right on.
Old Jun 15, 2018 | 09:03 PM
Dave64's Avatar
Dave64
2023 C2 of the Year Winner - Modified
2021 C8 of the Year Finalist - Unmodified
2019 C2 of Year Finalist (appearance mods)
St. Jude Donor '19-'20-'21
I installed a 1/2" wood spacer under mine on my '64 L76 and the peculating went away. On the Edelbrocks: I went thru both the 1405 and 1406 and nothing but problems with them running extremely rich, even after working a local engine builder/tuner. They seemed to be very, very sensitive to fuel pressure. My stock pump was putting out about 7 lbs pressure and it was too much. Fix your Holley.
Old Jun 16, 2018 | 11:23 PM
rotobug's Avatar
rotobug
Default easy fuel perculation fix
I had a constant problem with vapor lock on my 57. Wrapped the section of fuel line nearest the exhaust manifold with heat shield material. 2mm thick aluminum bonded to 3/16 inch non-woven polyester. Problem solved.
Old Jun 17, 2018 | 07:44 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
I'd rather take a beating than put one of those blingy, one-size-fita-all, Edelbrocks on a classic car.....I like many of their products but in the case of carburetors replacing original equipment its usually an owners' admission that a problem is beyond his ability to fix it.
Old Jun 17, 2018 | 09:38 AM
number3's Avatar
number3
your right frankie it is beyond my ability to fix it.
To carb spacer
