engine will not fire
Old Jul 8, 2018 | 03:11 PM
Lawnla's Avatar
Lawnla
2nd Gear
Default engine will not fire
327/300 corvette engine will not fire. Just turns over. I just replaced plugs/wires/ Dist. cap/rotor. Also replaced starter solenoid. Was firing and running before.
Thanks to all! Sorry for not getting back to your questions/suggestions. I figured to problem out....had the plug wires one hole off.
Old Jul 8, 2018 | 03:16 PM
Boyan's Avatar
Boyan
Default Engine
What do you NOT have? Spark , fuel or compression ?
Old Jul 8, 2018 | 04:11 PM
Donald #31176's Avatar
Donald #31176
Since wires & cap were replaced have you checked for correct wire firing order on cap.?
Old Jul 8, 2018 | 04:26 PM
Factoid's Avatar
Factoid
To be clear, did you replace these things as part of regular maintenance and then it wouldn’t start or did you replace them chasing a no start problem?
Old Jul 8, 2018 | 04:43 PM
warrenmj's Avatar
warrenmj
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
OPs initial post said it was running prior to the changes
Old Jul 8, 2018 | 04:44 PM
dmaxx3500's Avatar
dmaxx3500
start with the basics
1.do you have power going to the coil?
if yes
2.do you have fuel at the carb?
if yes
3.do you have spark at the plugs?
Old Jul 8, 2018 | 04:53 PM
GTOguy's Avatar
GTOguy
Verify that the rotor and cap is installed correctly. Then verify the firing order. Is it points or HEI?
Old Jul 8, 2018 | 06:03 PM
Lawnla's Avatar
Lawnla
2nd Gear
Regular maintenence.
Old Jul 8, 2018 | 06:24 PM
phil2302's Avatar
phil2302
Make sure coil is ok.
Old Jul 8, 2018 | 06:38 PM
Dan Hampton's Avatar
Dan Hampton
2018 C1 of Year Finalist
Did you replace the points/condenser? If you did, perhaps the points were not preset correctly. Make sure your coil wire and wire to the main terminal on the distributor is pushed on HARD and seals correctly.
Old Jul 8, 2018 | 07:26 PM
tbarb's Avatar
tbarb
Get a test light and make sure the small pink wire on the new solenoid has power when you crank the starter. Also make sure that same pink wire is attached to the solenoid small "R" terminal.
Old Jul 9, 2018 | 10:15 AM
65tripleblack's Avatar
65tripleblack
When you pull in the solenoid, you should see 12 v at the p/bl wire. Possible a bad solenoid not making internal contact.
Old Jul 9, 2018 | 03:30 PM
GTOguy's Avatar
GTOguy
Engine turns over fine. So it's not the solenoid. Engine ran fine before cap and rotor and wires were replaced. So it's about 100,000 to 1 that the coil happened to go bad. You can go down the rabbit hole if you want, checking coil voltages, solenoid wires, etc., or you can logically troubleshoot the system the same way the pro's do it. Your choice. Again: Points or HEI?
Old Jul 9, 2018 | 04:40 PM
tbarb's Avatar
tbarb
Post#1 mentioned the solenoid was replaced. How long could it take to check the pink wire going to the coil + for power while cranking?
Old Jul 10, 2018 | 08:25 AM
65tripleblack
The solenoid was replaced at the same time. The engine can turn over fine although if it's internally defective the R terminal won't become energized to supply power to the coil.
A quick check for the OP, would be to run a temporary jumper from the pos batt terminal to the pos coil terminal. Very simple. If the engine starts and runs then the problem is with the R terminal or the wire running from it to the coil.
Old Jul 10, 2018 | 03:54 PM
GTOguy's Avatar
GTOguy
Duly noted, 65. PLEASE don't send me to Florida!!!
Old Jul 10, 2018 | 05:52 PM
65tripleblack
Banishment to Floriduh is for capital offenses only.
To engine will not fire
