Won't Start
Old Jul 22, 2018 | 04:57 PM
JimSR's Avatar
JimSR
Default Won't Start
Car quit on way home will fire up and shut down I changed the ballast resistor, coil, points are good getting a good spark and gas to carb. Thinking I loss a ground some where. Any help would be greatly appreciated. Car is 63 S/W 327 /300. Thanks Guys Jim
Old Jul 22, 2018 | 05:21 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
no grounding. check you foul sock in the tank.
c6miller's Avatar
c6miller
I'm sure there will be more qualified members that will chime in but if you had a bad ground it would not even crank. Sounds like an issue with the carburetor, fuel filter or even bad gas. Check to make sure all your vacuum hoses are secure. Good luck, Peter
Old Jul 22, 2018 | 05:57 PM
Jriver's Avatar
Jriver
Are you saying the car starts then shuts down ? Does it back fire ? Does it start immediately after it turns off ?
Old Jul 22, 2018 | 06:25 PM
JimSR's Avatar
JimSR
​​​​​No back fire starts and immediately turns off
Old Jul 22, 2018 | 06:48 PM
Jriver's Avatar
Jriver
Sounds like an electrical issue, I’d check the ignition switch first
Old Jul 22, 2018 | 07:01 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Run a jumper from the positive battery terminal to the positive ignition coil terminal and try it.
Old Jul 22, 2018 | 07:20 PM
65 Pro Vette's Avatar
65 Pro Vette
C2 of Year Finalist (appearance mods) 2019
I agree with Frankie it sounds like you’re losing power when the ignition switch is off the start circuit. Like he said use a jumper to try it there aren’t many things in the ignition system in the C2’s Power to the ballast resistor. Easy to check.
Old Jul 22, 2018 | 07:33 PM
corvetteed's Avatar
corvetteed
St. Jude Donor '14 thru '26
it sure sounds like the ballast resistor, but, he said he changed the ballast resistor already. So, maybe the new one is faulty too??
Old Jul 22, 2018 | 11:51 PM
firemist1's Avatar
firemist1
I agree. Contacts in the ignition switch are probably corroded and causing a high resistance and dropping voltage to the coil. Be very careful about jumping a hot wire directly to the coil with a faulty ignition switch . You may back feed all the circuits when the ignition switch is on overloading that small gauge wire going to the distributor.
Old Jul 23, 2018 | 07:40 AM
Frankie the Fink
Army
Never heard of this happening.
The jumper test only need to be done for 3 seconds; if the car runs the problem is at the ignition switch; its connector or the intervening wiring.
Old Jul 23, 2018 | 01:07 PM
JimSR's Avatar
JimSR
Default It's Alive
Frist and for most Thanks for all the info you Guy's Rock😁 Found the problem the ignition wire on the switch had backed out the tab on contact had decompress so wire just pulled out of switch. Thanks Again for All The Info You Guy's Were Spot On. SAVE THE WAVE . Jim
Old Jul 23, 2018 | 01:25 PM
JimSR's Avatar
JimSR
Default It's Alive
Old Jul 23, 2018 | 05:50 PM
Jriver's Avatar
Jriver
Remember if your car shuts off without and sputter or backfire it’s almost always an electrical issue as opposed to fuel.
To Won't Start
