Carter carb
Old Aug 1, 2018 | 06:08 PM
Jriver's Avatar
Jriver
Default Carter carb
Cleaning and checking under the hood of my newly acquired 65 327 300 hp.
As I’m adjusting the choke and linkages I noticed the secondarys do not open at full throttle when the engine is off.
I know im getting old and can’t remember but don’t they open mechanically or are they vacuum operated?
Old Aug 1, 2018 | 06:28 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Most carbs have a secondary lockout to prevent bog when the engine is cold. Try holding the choke plate wide open and work the throttle.
Old Aug 1, 2018 | 06:33 PM
Jriver's Avatar
Jriver
I will check that after dinner but you are saying the secondary should open mechanically correct ?
Old Aug 1, 2018 | 07:22 PM
Frankie the Fink
Army
No. I said the secondaries could be locked out. I don’t know what type Carter carb you have. On the WCFB the secondaries are mechanical with air flow in the bores controlled by auxiliary air valves riding above the secondaries.
Old Aug 1, 2018 | 07:58 PM
Jriver's Avatar
Jriver
That’s exactly what I have. The secondaries open by way of mechanical linkage I was actually looking at the plate above them that must be vacuume operated
Old Aug 1, 2018 | 08:10 PM
Jriver's Avatar
Jriver
While looking at the carb I remembered another post when you told the OP to check the pin in the fuel pump. Here’s a picture of mine. In your photo it’s the rear of the pump in mine it’s the front.
Before I crawl under the car tomorrow let me ask should the pin extend that far out?
thanks for all your help
Jim
Old Aug 1, 2018 | 08:16 PM
Frankie the Fink
Army
Jim
Not just no but hell no!
Old Aug 1, 2018 | 08:17 PM
MikeM's Avatar
MikeM
Jim
Nope. You're a few thousandths away from a rollback.
Old Aug 1, 2018 | 08:27 PM
Frankie the Fink
Army
Perfect example of pin "walkout"..
There are several fixes for this and pictures on the forum...some make a bracket to block the pin moving on each side that's held by the fuel pump mounting bolts; others have used a pin with a head on one end and a groove on the other end which is secured by a "C" clip...
Old Aug 1, 2018 | 09:23 PM
dkleather's Avatar
dkleather
2016 C2 of the Year Finalist
The pin that failed. You can just see part of the hole in the arm that the pin was supposed to be through and how far the arm has moved forward.
I made a stop to put under each bolt when I installed the new pump.
Don’t drive the car with that pump. When I removed mine that did that and looked that way, the entire arm inside was twisted and bent from being off its pivot. I was lucky to have made it home. Looks like you’ve got yourself your first repair job but you’re fortunate you found it now. Dave
Old Aug 1, 2018 | 09:52 PM
Jriver's Avatar
Jriver
I’ll be getting a new pump tomorrow. Have the vette 6 or 8 weeks and not even close to my first repair. Replaced the carpets, master cyl,motor mounts,
repositioned the exhaust, repaired rev lamps and dash E brake lamp.... I’m sure I’m forgetting something.
But I enjoy my car!
Old Aug 2, 2018 | 07:18 AM
Frankie the Fink
Army
Removing the right front wheel will give greater access to fuel pump bolts and fuel line fittings BTW...
Old Aug 3, 2018 | 08:24 AM
Jriver's Avatar
Jriver
Removed the fuel pump and slid the pin back in with no problem. After everything I read I’ll reuse my original pump with a lock out bracket
thanks to everyone
Old Aug 3, 2018 | 08:36 AM
Frankie the Fink
Army
Good!
Your picture went in my archive for the next time someone asks me to describe the problem....classic...
I also found it interesting that the pin "walked" forward...it actually made me go out and check my fuel pump again
Old Aug 3, 2018 | 09:07 AM
dkleather's Avatar
dkleather
My pump arm was so torqued and twisted there was no way the pin would go back in. You were able to find the problem in time to prevent further trouble. Glad it worked out so well. Dave
Old Aug 3, 2018 | 10:50 AM
SWCDuke's Avatar
SWCDuke
As stated, the AFB has a secondary throttle lockout that prevents the secondaries from opening when the engine is cold. The auxiliary air valve is there to prevent "lean bog" from low air velocity/venturi signal when you floor the throttle at low revs. Notice that the shaft is offset, which allows manifold vacuum to open the valve, and they are typically full open at about 2500 revs.
With the engine hot, use a popsicle stick to open the aux. air valve, then open the throttle wide and check that all four butterflies are full open. There is a very good section on the AFB in the 1963 Corvette Shop Manual which you should have along with the '65 Supplement. The AFB section includes are the requisite adjustments and overhaul procedure.
Duke
Old Aug 3, 2018 | 11:50 AM
Jriver's Avatar
Jriver
It worked out so well mainly due the all the help from forum members like Frank and you!
Old Aug 3, 2018 | 01:32 PM
Frankie the Fink
Army
It doesn't hurt that you're proactive, take advice well and get back to forum members about how their suggestions went....
So many times some or all of this never occurs!
To Carter carb
