Backfeed through ignition switch
Old Sep 6, 2018 | 09:25 PM
Brian's Avatar
Brian
Default Backfeed through ignition switch
Backfeed through ignition switch. I first thought it was the ignition switch itself, but after changing that out I realize that there is a relay backfeeding my ignition. My Vintage Air air-conditioning, and radio continue to play no matter what position the ignition is in.
When I turn the car battery on a few relays in the front of the engine compartment that go with the Vintage Air start clicking. Has anyone ever encountered this before, and where should I start looking?
Old Sep 6, 2018 | 09:59 PM
65GGvert's Avatar
65GGvert
You don't have backfeed through the ignition, you have something wired wrong. At least one constant source is connected where it should be switched.
Old Sep 7, 2018 | 07:27 AM
Brian's Avatar
Brian
After 20 years of ownership its wired wrong? Why didn’t it show up sooner? Something has changed from one day to the next.
Old Sep 7, 2018 | 08:40 AM
65GGvert's Avatar
65GGvert
The only other explanation I can think of is you lost a ground somewhere and the voltage is feeding back through another device. I don't see how it could be the ignition switch. It's going to take a voltmeter/ohmmeter and some troubleshooting.
Old Sep 7, 2018 | 08:41 AM
65GGvert's Avatar
65GGvert
Have you really had Vintage Air for 20 years?
Old Sep 7, 2018 | 08:49 AM
Mr D.'s Avatar
Mr D.
You need to isolate what system is being powered on when it shouldn't and troubleshoot each of those independently. My guess is one issue is causing several issues and as pointed out above check for a ground issue as that can cause some crazy things to happen.
Old Sep 7, 2018 | 10:23 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Turn the Vintage Air temp control all the way to warm setting and then see if relays click with the battery connected.
Old Sep 7, 2018 | 11:17 AM
Factoid's Avatar
Factoid
I installed my first VA in 1997 in a 1954 Studebaker Commander (after seeing Jack’s 1953).
You already changed the ignition switch, so start tracing power sources from the relays back to the source. Shouldn’t take you long to find the problem.
Old Sep 7, 2018 | 12:08 PM
Robert61's Avatar
Robert61
Possibly the circuit board in the VA has failed.
Old Sep 7, 2018 | 04:08 PM
Brian's Avatar
Brian
i installed it myself. Around year 2000, as I remember.
Old Sep 7, 2018 | 04:12 PM
Brian's Avatar
Brian
Thanks everyone. I will bring your comments to my mechanic on Monday morning.
Old Sep 7, 2018 | 08:27 PM
TCracingCA's Avatar
TCracingCA
I hope you don't burn your car to the ground.
Backfeed????? No current is running thru your switch in one direction, as current is going in the other direction!!!! Joke>>>>> you don't have AC, but DC with Amperage is the more proper term that should have been used. Current confuses everyone (as you have hole flow or electron flow! ).
One, why do you guys all try to run crap off of the ignition. If something happens, I want the simpliest power run from Battery, Starter, ignition, coil period. Then I pick up a 12V supply for everything else from the fuse block! Not knowing what all you have with that aftermarket Vintage air unit, I would guess you definitely wired something hot, that shouldn't be hot. And surprised you aren't popping fuses, or seeing sparks, or arcing, or FIRE!!!!!!!
If a relay is actuating, then it should be doing something for something. And I have see some real wild and weird wiring in all of my years.
Guys if you can't sketch a simple diagram, of how and what you have connected, you probably shouldn't be working on it. I am sure the Vintage air needs Voltage, and the instructions probably give you suggestions, as to where to grab that from. I am trying to think what else one of those would need, other than ground, and maybe switching runs, etc.
I think you need to trace and diagram! What component, what the spade or terminal have on it, etc..
Old Sep 7, 2018 | 08:38 PM
65GGvert's Avatar
65GGvert
Anybody translate that for me?
Old Sep 8, 2018 | 07:28 AM
Frankie the Fink
Army
My point in post #7 was that sometimes, when I turn my key on with my Gen IV Vintage Air system and the temp control set to full cold I hear s "snap" behind the glove box; I assume its a relay calling for A/C -- even before the engine is running.
This sounds akin to what the OP is experiencing. I think its normal..
Can't say if this is the OP's symptom or not - I also am not a fan of tying accessories into just any power source on these cars. Some electronic points conversion systems can have a problem if you do this; often your dash battery gauge will read wrong if you do so....
Old Sep 8, 2018 | 09:51 AM
Robert61's Avatar
Robert61
Vintage Air has one large red wire coming from a circuit breaker direct to positive battery. They wired this themselves unless it got changed. From this breaker it feeds the relays for the heater control valve, cut off, and the compressor. Another wire off of the breaker goes to the blower fan. A fault in their design to me is constant power to the heater control valve when the switch is on and AC is selected. This should be the only relay you hear click when you power up. The Compressor relay would click also if you have the AC selected. If you have heat selected then you will only hear the AC relay click. FTF mentioned this way back. You have a violet wire from the ecu that is switched power and possibly the orange wire for wide open throttle kill that is switched. You say your VA and radio continue to operate regardless of switch position. Does this mean with the key in off or removed?
Old Sep 8, 2018 | 09:56 AM
Robert61's Avatar
Robert61
i think he said you can get the runs off of your ignition and it burns like crap or something like that!
Old Sep 8, 2018 | 10:48 AM
Donald #31176's Avatar
Donald #31176
Might not be relevant but in a 60-62 ignition switch there are 2 pink wires from the harness. One is for the accessory pole and the other battery pole. If those wires are reversed you will get the same results as the OP. The radio, heater fan , turn signal will all work with the ignition switch in the locked position.
To Backfeed through ignition switch
Old Sep 8, 2018 | 02:34 PM
65GGvert's Avatar
65GGvert
The curious thing is he says it clicks as soon as he connects the battery, not the key
Old Sep 8, 2018 | 02:40 PM
Frankie the Fink
Army
Some connect the battery with the key in the ON position without realizing it...
Anyway - not sure what the concern is if the battery isn't running down or not charging..
Old Sep 9, 2018 | 12:48 PM
Brian's Avatar
Brian
I’ve been shutting the battery off. But there is a perisidic draw.
I thought it was the relay for the Vintage Air, but it is the main relay located on the right side of the radiator support.
