[C2] TO Bearing problem
Old 11-14-2018, 07:11 PM
  #41
Sky65
Support Corvetteforum!
Sky65's Avatar
St. Jude Donor '05, '09, '15
Valuable clutch info from Lars.
https://www.corvetteforum.com/forums/c1-and-c2-corvettes/3678204-some-facts-and-numbers-on-inadequate-clutch-pedal-travel-range.html
Tom
alexandervdr (11-15-2018)
Old 11-15-2018, 02:12 AM
  #42
alexandervdr
alexandervdr's Avatar
Originally Posted by Sky65
I don't believe the clutch fork is the problem IF it is the correct fork for the other clutch parts installed. The damage on the fork did happen on one drive. It has had an issue for a while. I still think it Is the result of incorrect geometry, not the fork itself. Is it the correct flywheel? Has the flywheel been over-machined moving the pressure plate mount surface too far forward? Are the pressure plate and disc correctly manufactured? Does your pressure plate have raised curved fingers or flat where the release bearing contacts it? Can you post pics of your other clutch parts? It may help.
Just trying to help.
Tom
My set-up is all plain standard GM parts. The engine is a new standard Goodwrench crate that came with the flywheel mounted. The bell housing is GM OEM, the ball stud has the correct height. The clutch/pressure plate are standard . The bearing is standard. Remains the fork itself, which I took from the car when bought. I found it to be curved upwards, not sure this is as original. Will see when the new fork comes in somewhere next week. Will report back
Old 11-15-2018, 02:28 PM
  #43
buns
buns's Avatar
Old 11-15-2018, 02:29 PM
  #44
buns
buns's Avatar
Old 11-15-2018, 03:01 PM
  #45
KC John
KC John's Avatar
C2 of Year Finalist (appearance mods) 2019
What about the '63? Is that 1 year only?
Originally Posted by buns
Old 11-15-2018, 03:23 PM
  #46
buns
buns's Avatar
Yes, one year only.
Old 11-15-2018, 05:13 PM
  #47
Sullyvette
Sullyvette's Avatar
John Z, I've read so many insightful articles written by you. Can you please give us all a little history of who you are, some of your past experiences? I'm sure it would prove to be some good reading ! Thx, Sully
Old 11-16-2018, 08:41 PM
  #48
JohnZ
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
Sully -
In a nutshell, BSME '62 and MBA '64 from Michigan State, Army helicopter instructor pilot, GM 1964-1985 (Chevrolet and GMAD Product and Production Engineering, including 2 years in the Corvette Group), head-huntered out of there by Chrysler in 1985 when Roger Smith's reorganization nearly crippled GM, 17 years at Chrysler as a Chief Engineer, Director of Manufacturing Engineering, and six years as the Viper Plant Manager. Retired in 2001 at 60, was very active in NCRS (Master Judge, Chairman, Michigan Chapter 2001-2006) until my health took a tumble in 2016. Sold my cars and now leaning back on my long-time secondary hobby (guns and gunsmithing), which better suits my current physical capabilities.
The following 3 users liked this post by JohnZ:
Hermn59 (11-17-2018), larrywalk (11-17-2018), Sullyvette (11-20-2018)
Old 11-19-2018, 09:39 PM
  #49
Sky65
Sky65's Avatar
OP did you fix it?
Tom
Old 11-20-2018, 01:46 AM
  #50
alexandervdr
OP did you fix it?
Tom
No, still waiting for the new fork to come in. Still stuck in red tape and shipping admin on your side of the atlantic ocean
Old 11-20-2018, 10:42 AM
  #51
Sky65
Sky65's Avatar
Well that sucks!
Tom
Old 11-22-2018, 04:17 AM
  #52
alexandervdr
new fork came in this morning. Is 100% identical to the old one I took out, except that the ball spring is MUCH firmer and the indent where the ball goes is more pronounced on the edges. Will take a while to get the car up and running again, cause in the meantime I am transforming to a removable cross member.
Quick Reply: [C2] TO Bearing problem
