Are there any issues (or techniques) to replacing the diff carrier mounting bracket with the rest of the rear end/suspension assembled? My '64 has the "clunk" and elongated holes addressed in TSB 1069....my plan is to replace it with a reinforced unit from Van Steel. Additionally, rubber or poly pinion bushing while I'm in there?
Definitely replace the snubber with rubber. I’ve poated that TSB many times. I don’t recall if it had installation instructions though.
It doesn't....looks relatively straight forward....It looks like the hard part is going to be getting a wrench on the bolt that goes through the snubber....need to brake out the manual tomorrow and take a look at what it says.
Thank you for this timely post I was planning to reinstall my rear differential tomorrow and was wondering why someone would tack weld washers to this bracket,
They did a really poor job as two of them have broken loose I am tired of waiting on parts so I think I will give them a more thorough welding and carry on,
I just ordered one from Van Steel along with the new rubber snubber and all of the associated hardware. I think it was right around 90 bucks for everything. Hopefully there isn't much of a load on that bracket while stationary and it comes apart relatively easily.... well see.
Good timing, I just did a repair to a housing most likely from a loose bracket in the past. As mentioned the front holes took most of the abuse, the 63-4's has tapped front holes and used short 7/16-14 bolts and that didn't work out too good. In 65 they went with a through hole but the brackets were still cheesy, until 69 when a 1/4 plate was welded on and that took care of the issue for the most part. So what will happen at times is the hole in the housing enlongates not fully supporting it. It will work but can be repaired by boring and sleeving. The end result is a steel sleeve that is very strong and will last the life of the car. The bore has to be small enough that it doesn't cut through the casting into the oil passage under the front seal. So this shouldn't be done with a hand drill although I suppose that can be done. This one is now back to the original configuration. Just something to check when replacing a bracket or rebuilding a diff.
Much appreciated! My car had less than 500 miles on it post restoration in the 80s, so I'm hoping there is no damage to the housing itself. If my experience on with this car holds true, its simply that the original bolts were not properly torqued when it was put back together. Either way, Im going to install the reinforced bracket and new snubber in the hopes to not have to address it again.
Soooooo.....has anyone done this repair with the body on the frame? Based on the length of the bolts, I don't think you can remove them in order to change the brackets with the body on....they'll hit the tub on either side of the driveshaft tunnel....
If you have the original 63-64 threaded front bolt holes, each short forward bolt can be removed and the bracket swung down with the body and pumpkin in place. The rear through bolt is removable with the body in place. A front through bolt may not have as much room, but loosening the four pumpkin bolts should provide enough pinion drop angle to safely remove the through bolt below the body without dropping the entire pumpkin.
The pinion snubber bolt is more easily wrenched with the driveshaft removed.
I see what you're saying, the problem will then become, installing the new 65 and later, reinforced bracket with the two long through bolts as there will be no way (as far as I can tell) to get the forward through bolt installed once the bracket is swung back up into position.
are you planning to drill out the diff to install the through bolts?
hmmmm....I hadn't, but in rereading the responses above, it has become apparent that I was/am not fully grasping the solution to the problem here.
So in the original 63-64 bracket arrangement, is it typically the bracket, or the holes in the differential itself that get elongated, causing the clunk?
Am I correct in understanding that the only complete fix to this issue is to remove the differential, drill the through holes, install the steel sleeve, and then install the two through bolts?
I think I would remove the bracket hoping to find good threads in the diff with a worn bracket replace original style bolts and bracket with Loctite and retorque on occasion,
That makes sense....I imagine you need slightly longer bolts to compensate for the additional thickness of the reinforced bracket (assuming the threads in the diff are good)?
I appreciate the help in sorting this out!
If the 63-64 forward bolts come loose, the bracket can move (making the clunk) and eventually wear and crack the holes in the bracket. The loose bolts being rocked by the bracket shear will also damage the threads in the pumpkin (the more critical damage). The solution is to keep the bolts tight, and the potential for thread and bracket damage is minimal. Tight bolts and brackets do not wear or crack.
The thread damage motivated the through hole bolt change for 65'.
The same clunk and bracket damage can happen with the later through bolt, if it comes loose, but without threaded bolt holes the pumpkin damage is through hole wear.
Eventually GM reinforced the bracket, in the C3 era.
