[C1] Strengthened Area Behind Rear Door Jamb
Old 11-12-2018, 07:55 PM
njfl
njfl's Avatar
Default Strengthened Area Behind Rear Door Jamb
As shown in the pictures, the area behind the door jamb appears to be strengthened by someone filling in the area with a large amount of resin (maybe cloth too, but can't tell). It's like this on both sides and it has broken loose from the jamb on both sides. Was this done at the factory to strengthen that area or did someone else do it? I can see that if it isn't there and you lean on it, it is susceptible to cracking.
Old 11-12-2018, 08:19 PM
bellyjello
bellyjello's Avatar
I’ll try to check my ‘62 project tomorrow. If I remember.
Old 11-12-2018, 09:10 PM
Robert61
Robert61's Avatar
Received 1,536 Likes on 1,067 Posts
Someone definitely put that in. Its not factory.
Old 11-12-2018, 09:29 PM
njfl
njfl's Avatar
Thanks. I can't see why as the fiberglass around it appears to never have been damaged.
Old 11-12-2018, 09:56 PM
mmaturo
mmaturo's Avatar
I does need it however. going to add reinforcing there and the entire lip on my not so perfect 60 driver. mine is cracked there.
Old 11-12-2018, 10:00 PM
njfl
njfl's Avatar
I'm going to leave it as it doesn't appear to hurt anything and it definitely makes it more resistant to cracking.
Old 11-13-2018, 05:01 PM
Roger Walling
Roger Walling's Avatar
Received 1,627 Likes on 668 Posts
"m not sure what I am looking at but is that near where the lock latch is mounted?
may be someone cut a hole to get at the internal lock plate?
I has to reinforce the very top of my pillar because of cracking.
Old 11-13-2018, 05:21 PM
bellyjello
bellyjello's Avatar
wish I took a better picture.
njfl
njfl's Avatar
This is also at the top, not near the latch plate.
Old 11-13-2018, 05:23 PM
bellyjello
bellyjello's Avatar
It seems sturdy without.
To Strengthened Area Behind Rear Door Jamb
Quick Reply: [C1] Strengthened Area Behind Rear Door Jamb
