Tach Bouncing
Tach Bouncing
I have a 63 with a rebuilt tach gauge by Bill Harrison. All of my other gauges on this car and a previous car were rebuilt by him and have worked/looked flawlessly. The needle bounces at idle and low rpms but at about 2500, it is steady all the way up.
I read on another forum that a hard turn in the cable could be the problem. Any truth to that? Running a new tach cable would not be that difficult.
TIA
TIA
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
TIA
TIA
Yes a hard turn in the cable housing can cause a binding of the cable in the housing...and also I have seen that lubing the cable can cause the same problem also due to the lube...depending on what type is used...can get thick and cause the cable to bind and pop also.
DUB
DUB
Since the tach is rebuilt I would suspect the cable is worn. The tach cable has to take a couple pretty sharp bends from the distributor to the firewall penetration and those sharp bends increase the cable wear on the cable housing protective sheath inside. Some (including myself) have installed a 90 deg adaptor on the distributor to lessen the bends. Probably helps as mine has remained dead steady over 25 years but I don't have that many miles on it. And GM sent these cars out the door without the adaptor and they had smooth tachs for years.
You could try lubricating it. Lately I've been using this Tri Flow dry lube with some success.
https://www.ebay.com/p/Tri-Flow-Supe...a1afdbffe78fce
But cable lube is kind of a crazy subject with people using everything from chassis grease to the old standard of dry graphite, to auto transmission oil.
One other issue to check is the correct indexing of the distributor..Correct indexing will allow sufficient movement to time the engine as well as aligning the tach coupling with the cable.
Tach Bounce
I currently own a 66 and had previously owned a 66 a number of years back. The tach's on both bounce quite a bit under hard acceleration. I believed this to be normal in mechanical tach's. Am I understanding that this is not the case and that I can improve this with an instrument rebuild, new tach cable possibly with this adapter?
C2Dude (11-17-2018)
Thanks for the info. Over the weekend, it stopped completely. I checked at the distrib and it is still connected--I havent looked under the dash yet. I will try to trouble shoot and lubricate--it has never been lubed under my ownership.
I will say that Donald's comment about indexing is interesting. My distrib probably needs to move over 1 tooth as the vacuum advance can is touching the intake to get my initial timing. The motor is new and still needs to be tuned but that might be a consideration as well.
I will say going from the tired 350 when I bought the car years ago to this jumpy 327 is NICE!
As far as indexing the distributor in a Corvette there is only one position that allows proper timing , proper alignment of the cable & coupling. Moving the distributor a tooth or 2 is not the complete answer to get the correct index. You ll need to search the archives .
