Clock Removal
Old Dec 28, 2018 | 12:27 PM
blue max's Avatar
blue max
Default Clock Removal
It's been several years since I removed and repaired the clock on a 65. I didn't find a thread on that. Would someone point me in the right direction on how to remove it? Not sure what's wrong with it as I just got the car
I just found tons of info right in front of my face. Thanks
Blue Max
Old Dec 28, 2018 | 12:55 PM
65hihp's Avatar
65hihp
Every possible way is described in this thread. Easiest is to just remove right side panel, reach in and disconnect, and remove clips. Pull clock out. Removing glovebox gives you even more room.
Don't bother pulling the cluster forward. That is way overkill for such a simple task.
https://www.corvetteforum.com/forums...k-removal.html
Old Jan 2, 2019 | 01:06 PM
blue max's Avatar
blue max
Remember now Just pull side panel out reached up remembered how to remove clips out Now who to go to to get it working.
Old Jan 2, 2019 | 01:16 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Clock Works or "Corvette Clocks by Roger"...
Old Jan 2, 2019 | 02:35 PM
65vette396's Avatar
65vette396
I second the clock works suggestion. Fast turnaround and very reasonable.
Old Jan 2, 2019 | 02:44 PM
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
Clock Works
Fast service and turn around
They will install a NOS movement and it will run and look like new when you get back.
Very reasonably priced too.
Don
To Clock Removal
