[C2] Wrong Alternator?
Old Dec 30, 2018 | 12:53 PM
jsans's Avatar
jsans
Default Wrong Alternator?
I purchased an aftermarket replacement alternator for my 65. The brand new battery wasn't getting charged so I assumed the 30 year old alternator was no longer functioning. The voltage gauge was reading straight up zero. I installed the new alternator without issue, all of the connections matched correctly, then I realized it's a higher 55 AMP alternator and not the proper 37 AMP made for vehicles without A/C like mine.
Is there any concern with having a higher amperage alternator installed in the vehicle or could I damage something? Everything appears to be normal when it runs.
Old Dec 30, 2018 | 01:03 PM
Dennisscars's Avatar
Dennisscars
After verifying no loose wires, check regulator. First mine was under charging (use shop voltmeter not dash) then I cleaned regulator contacts then it was max charging .
Put a direct drop in solid state one on, best thing I ever did, wish I had done that years ago.
Old Dec 30, 2018 | 01:06 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
The higher amperage unit will not hurt anything, it will only put out as much current as needed, no more.
Doug
Old Dec 30, 2018 | 01:09 PM
Duck916's Avatar
Duck916
I don't believe a higher output alternator will cause any problems. If the regulator is functioning correctly, it won't demand any more output from the alternator than is required. So, basically, you've got some extra capacity that won't be used. No problem.
If you are concerned at all, just check the voltage across the battery terminals while the car is running. If it's 13.7-14.3, you're fine. If it's 15+, you've got a problem (which would be the regulator, not the alternator, anyway).
Old Dec 30, 2018 | 01:25 PM
R66's Avatar
R66
I Agree - The voltage regulator controls the alternator output and thus the alternator will only put out what is needed to maintain the battery charge and run accessories.
If you have not installed an electronic voltage regulator, I would do so for the intent of protecting the battery and wiring, as the original mechanical points voltage regulators sometimes stick closed and allow the alternator to induce full amperage to the battery and accessories. The electronic voltage regulator is much more sensitive to over current and will generally open if they fail.
Have a beer and enjoy your car. No worry.
Old Dec 31, 2018 | 03:56 AM
jsans's Avatar
jsans
Much appreciate the responses from this knowledgeable community.
To Wrong Alternator?
