Lectric Limited ques
Old Oct 30, 2002 | 05:31 PM
Jimbo64's Avatar
Jimbo64
St. Jude Donor '09
Default Lectric Limited ques
Know some of you have used their wiring by posts. Couple questions- Is it a quality product. [got a dozen catalogs that
offer wiring harnesses from different sources.] Do their dash harnesses come with new fuse blocks. [couldn't tell by
their catalog. Also see on the complete wiring upgrades [not sure if i need to go there yet] there is a basic and a delux
version. Is the delux worth the extra bucks. Final ques, would you buy their product again. Thanks Jimbo 64
:seeya :cheers:
Old Oct 30, 2002 | 05:42 PM
Mark Lovejoy's Avatar
Mark Lovejoy
Default Re: Lectric Limited ques (Jimbo64)
I used Lectric Limited products when I did my '58. Replaced the front and rear harnesses however reused the main dash and fuse block. They fit well, and from what I could tell, matched existing very well. I will use them again.
No affiliate yada, yada, yada.
Old Oct 30, 2002 | 06:20 PM
67435animal's Avatar
67435animal
Try the competition M&H Electric at http://www.wiringharness.com. They make a superb product that, last time I checked was priced lower than the Corvette catalog vendors.
I have used them for an engine harness, a backup switch & harness, and spring ring cables. Everything was an exact duplicate, fit perfectly, and was in stock. When I called to order, it was at my door 3 business days later.
Old Oct 30, 2002 | 06:34 PM
Cmacsvette's Avatar
Cmacsvette
Jimbo64, you asked, so I'm going to give my 2 cents. The only thing I ever bought from LL, was set of spark plug wires, 67 w/ sst shielding, you've seen them. I absolutely hated them! They looked real pretty, ohmed out O.K., but what I didn't like, was the lack of strenght in the material. Some of the boots tore the very first time I tried to take them off and I don't blame myself for abusing them and they weren't CHEAP!!!!!!! That was six years ago, so maybe their using better compounds now, who knows. After that, LL left me with a neg. attitude. When it came time to buy wire harnesses, I called Pacific Corvette to find out who they used. They buy from M&H Electric Fabricators Inc., out of Calif. 562-926-9552. They like them and and from what I understand, if they build it, they buy from them. The very first harness I bought from M&H when the 7 car was still running, was a TI harness and it fit like a glove and performed very well. If you want to ask more about their workmanship, call Pac. Corvette at 1-800-228-2857 and ask for Bill. I can tell you one thing, for all the years they've been around, they know what works for them and what don't. Anyway Jimbo64, that was probably 3 cents instead of 2 cents, sorry.
I know some of the other guys have used LL, so you'll get their thoughts.
Good luck, Craig ;)
BTW, yes, the under the dash harness by LL, I think comes w/ fuse block, I know my M&H did.
[Modified by Cmacsvette, 10:40 PM 10/30/2002]
Old Oct 30, 2002 | 07:44 PM
Daffy2's Avatar
Daffy2
I used LL main and rear harness when I redid the '64. The rear was perfect, but the main (included the block) had a couple of color discrepancies and the loop down to the headlight open/close switch was a bit short, so I had to mount the control upside down to get a fit and even then it was a stretch. All of the bulb sockets were first rate.
Daffy
Old Oct 30, 2002 | 07:48 PM
John McGraw's Avatar
John McGraw
I have used them for solid axle harnesses and I am very satisfied with them.
:seeya
Old Oct 30, 2002 | 09:49 PM
Andy B's Avatar
Andy B
Jimbo,
I recently bought an engine harness from LL after a short in the alternator burnt the original. The harness seems to be first rate, the colors of the wires are all correct and all the small details are there. For example the sleeve on the wire that runs to the water temperature sender looked just like the original stuff.
My electronic order was in before seven a.m. on Monday morning and it was delivered by ten a.m. Thursday morning. They offer “free” shipping on internet based orders and hit ya for five dollars in handling fees. One word of caution, I did notice they are not using any sort of secure socket layer service on the order form of their web site so your CC info is basically being sent as plain text over the internet. I took my chances and so far so good!
Had I known how good the new harness was going to look I would have bought the full car set to begin with. I’m not sure about the differences between the basic and the deluxe version but I would buy from them again.
Andy B
Old Oct 30, 2002 | 09:57 PM
LouieM's Avatar
LouieM
Regarding fuse blocks, M&H's online site says: "All of our 1958-1978 dash harnesses include fuse boxes that are set up to use Buss style (aka Glass type) fuses, as original." They also have harnesses to convert to an alternator with an internal regulator, and similar mods. I've never bought from them, just have their catalog.
Old Oct 31, 2002 | 11:18 AM
JL66REDCPE's Avatar
JL66REDCPE
C2 of Year Finalist (stock) 2019
I have also purchased parts from LL. A set of T3 headlights and 2 pair of BB shielded spark plug wires. I have to agree with a previous poster in that the boots on the spark plug side are crap. I have also had them tear upon removal and yes I twisted the boot bfore I tried to remove it. It actually tore while twisting. I called LL and explained to them what happened. They sent me 3 replacement boots at no charge.
Old Oct 31, 2002 | 12:44 PM
MasterDave's Avatar
MasterDave
Moderator
I got my main harness from LL along with their schematic. Everything fit perfect. All the lights and gauges lit right up and things are still working today. Yes, it included a new fuse block and was already wired to the system.
Old Oct 31, 2002 | 05:11 PM
Swamp Thang's Avatar
Swamp Thang
Bought the engine bay wiring harness for a '78 from LL - very satisfied, everything fit
Old Oct 31, 2002 | 08:47 PM
Ih2lose's Avatar
Ih2lose
[QUOTE]Jimbo64, you asked, so I'm going to give my 2 cents. The only thing I ever bought from LL, was set of spark plug wires, 67 w/ sst shielding, you've seen them. I absolutely hated them! They looked real pretty, ohmed out O.K., but what I didn't like, was the lack of strenght in the material. Some of the boots tore the very first time I tried to take them off and I don't blame myself for abusing them and they weren't CHEAP!!!!!!!
I had the same excact problem as cmacsvette.And when I called to get a replacement I was told they are not meant to go on and off.I explained if I had been told that in the begining I never would have purchased them.To make a long story short I have not made a purchase from them since.
[Modified by Ih2lose, 7:49 PM 10/31/2002]
Old Oct 31, 2002 | 11:39 PM
Jimbo64's Avatar
Jimbo64
St. Jude Donor '09
Hey forum people, thanks as usual for the great inputs concerning my question about lectric limited. Not quite sure what
route i'll go but will check out someother suppliers also. Does sound like they have a problem with ignition wiring if the
boots keep tearing. Again thanks and if anyone else has some experience with any supplier, the inputs are appreciated.
JIMBO 64 :cheers: :seeya
Old Nov 1, 2002 | 08:20 AM
tapio's Avatar
tapio
I bought main dash harness from LL and it was a disappointment. Some wires were inch or two too short - I hade to cut the new harness and add some extra wire to get perfect fit. I emailed them about this and they never answered. In my opinion, they were arrogant and this particular product was just lousy. Will never again buy their products. So, if you have any alternatives, you might want to study them first.
Old Nov 1, 2002 | 01:21 PM
Cmacsvette's Avatar
Cmacsvette
Default Re: Lectric Limited ques (Ih2lose)
Ih2lose,
MAN!..............O.................MAN! , there ain't a tall enough ladder built to get off the horse, that they could put me on! Your quote "I was told they are not meant to go on and off".................................... .........GEE!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!WIZZ!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!, I WONDER WHAT THEIR DEFINITION OF ON AND OFF IS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!OH I GOT IT.......... ONE TIME....................RIGHT!!!!!!!!!OH GIVE ME A BREAK!!!!!!!!!!!!!!!!!!!!!!
We guys out here are paying WAY to much money for this crap and then to top that, we have to put up with the CRAP THEY DISH OUT TO A CUSTOMER WITH A CONCERN!......... GIVE ME ANOTHER BREAK!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Larry, :cheers: :cheers: :cheers: :cheers: Good for you. :yesnod:
Sorry guys, I just had to vent a little, but I'm doing much better now. ;
[Modified by Cmacsvette, 5:58 PM 11/1/2002]
Old Nov 1, 2002 | 01:41 PM
MasterDave's Avatar
MasterDave
Moderator
Default Re: Lectric Limited ques (Cmacsvette)
Ih2lose,
MAN!..............O.................MAN! , there ain't a tall enough ladder built to get off the horse, that they could put me on! Your quote "I was told they are not meant to go on and off".................................... .........GEE!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!WIZZ!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!, I WONDER WHAT THERE DEFINITION OF ON AND OFF IS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!OH I GOT IT.......... ONE TIME....................RIGHT!!!!!!!!!OH GIVE ME A BREAK!!!!!!!!!!!!!!!!!!!!!!
We guys out here are paying way to much money for this crap and then to top that we have put up with the CRAP THEY DISH OUT TO A CUSTOMER WITH A CONCERN!......... GIVE ME ANOTHER BREAK!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Sorry guys, I just had to vent a little, but I'm doing much better now. ;)
Do not know what to say bro, mine fit perfectly and all is still working after 2 years. I'm happy.......
Old Nov 1, 2002 | 01:49 PM
Cmacsvette's Avatar
Cmacsvette
Default Re: Lectric Limited ques (MasterDave)
Hey Dave,
Now you understand, I'm talking spark plug wires here. I'm not talking about any other wire harnesses from LL as I stated in my first post. The only current carrying materials I've ever bought from them, is spark plug wires. So are you saying you bought spark plug wires from them??????aaaaaaaand?????
Craig :cheers:
[Modified by Cmacsvette, 6:50 PM 11/1/2002]
To Lectric Limited ques
Old Nov 1, 2002 | 07:36 PM
Ih2lose's Avatar
Ih2lose
[QUOTE]Ih2lose,
CRAIG
Why dont you tell us how you realley feel dont candy coat it this time.I know how you fealt when you wrote that.I fealt the same way when I called them.
Old Nov 1, 2002 | 10:00 PM
Cmacsvette's Avatar
Cmacsvette
Larry,
...........after I wrote that, I noticed I had a bit of a problem, there was SMOKE, coming out of my explanation key. It was in total melt down, :eek: :lol: and my high horse was growing @ a rate of 23' per second. :eek: :lol: I'm sure you do know how I felt, I knew how you felt.
Anyway it's Friday and I'am doing much better now. :yesnod: :cool:
Craig :cheers:
Old Nov 2, 2002 | 07:15 AM
67435animal
Jimbo, no question in my mind. Buy from M&H. When I bought my Spring Ring cables from them, I mentioned to the tech guy that I had some feedback about their backup light switch. We spent 15 minutes discussing it and he said he would bring it up at their next design meeting. They LISTEN!
And, I asked why they didn't advertise as much as, say, LL. He said, 'We get a lot of referral business. If we advertised, we would not be able to handle the demand and I'd be concerned that our quality might suffer.'
Buy M&H. Bye, bye, LL.
[Modified by 67435animal, 6:16 AM 11/2/2002]
