[C2] Dash harness help
Old Jan 16, 2019 | 11:01 PM
ovlrcr's Avatar
ovlrcr
Default Dash harness help
Almost ready to pull the old harness and started to compare to the new lectric limited harness. The two heavy gauge red wiras are connected to something I don't recognize. Is this a fuasble link? The new harness has the two red wires but it seems I need another piece of the puzzle to make it right.
Old Jan 16, 2019 | 11:03 PM
65 Pro Vette's Avatar
65 Pro Vette
C2 of Year Finalist (appearance mods) 2019
They go to the circuit breaker that snaps into the vent area on the driver side. It looks like it’s pictured in your second picture.
Old Jan 16, 2019 | 11:29 PM
ovlrcr's Avatar
ovlrcr
Thanks 65 Pro Vette. I will add that to my list.
Old Jan 17, 2019 | 08:40 AM
Gavin65's Avatar
Gavin65
if you don't have one a schematic is helpful.
Old Jan 17, 2019 | 09:23 PM
bman4261's Avatar
bman4261
It's infinitely easier to connect up your new C2 harness with the dash out of the car as opposed to lying on your back and straining your neck. Pull the dash frame and support it with light weight chain from some eye hooks in your garage ceiling. With the dash cluster and radio installed on the frame, you can easily make a majority of the harness connections with it on your workbench. Then just take it to the car and all that remains (after bolting the dash frame in place) is fit the male plug harness into the female coming thru the firewall. This is how I did my '67 Corvette a few years ago. Saved me lots of pain and frustration.
Old Jan 17, 2019 | 09:34 PM
lars's Avatar
lars
See my post on harness installation a few years ago. You can remove the gauge cluster panel, install the entire harness, and then feed it all right back in:
https://www.corvetteforum.com/forums...d-process.html
Lars
Old Jan 18, 2019 | 06:35 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
I agree - the breaker for the headlight motors IIRC...
Old Jan 18, 2019 | 11:57 AM
Tampa Jerry's Avatar
Tampa Jerry
As Frankie said, that is for the headlight motors. It can also be used for power windows. Of course you need one for each. Since these are hot, I added a cover from NAPA for both of my circuit breakers. Jerry
Old Jan 19, 2019 | 10:57 PM
ovlrcr's Avatar
ovlrcr
Thanks to everyone for the input. I Should be able to to slide the dash cluster back in tomorrow after I install the heater box.
Old Jan 20, 2019 | 06:51 AM
Frankie the Fink
Army
Before you put anything else in.....this is the time to deal with cockpit firewall insulation, rebuild the fresh air vents if needed, lube the wiper under-dash arm pivots and check that clutch pedal for side to side movement to see if the top weld has broken...
Frankly, I'd pull the pedal ***'y if you haven't already done so and put new bushings in while examining things.
To Dash harness help
