Greetings! I'm trying to sift through multiple online Guides on a '64 Engine stamp and wondering if I can get your help? The VIN matches, but then the character placement is off from what I'm reading online. It is supposed to be a "numbers matching", though there is ZERO documentation / paperwork. I thought the "engine" type was to be in the 9th & 10th position? It ends in RE (or RF), and it is supposed to be an 365hp engine. The trim plate seems to match up to year, coupe, black interior, silver exterior, etc. It has been restored, and is in nice condition....though again, actual miles (pre-restoration) is unknown. Anything else you can tell me would be greatly appreciated.
I'm certainly no authority, but the whole thing looks correct/original etc. I referenced a couple of sources and RE should be correct as you have described the engine. Dennis
What happened to the trim tag - did someone shoot it or drill it?
Interesting question. I don't know. I know the car was a full frame off restoration within the last 5-10 years. No documentation...so not sure how or why those holes would occur in the process.
Thanks for the confirmation everyone. I get that the first part 7 numbers are a partial VIN, and that the 8th position designates "Flint, MI". The Suffix "RE" references the 365hp L76 engine, but what do the I206 refer to in the middle?
I would say sometime in it's life someone has added a bracket there for a tape player, radar detector, etc
2020 Corvette of the Year Finalist (track prepared))
2019 C1 of Year Finalist (track prepared)
So December 6, 1963 is the date that the engine was assembled.
The engine's casting date is not a stamp but is cast into the block itself. It is on the right side of the back of the block, just down the back of the engine from the distributor. It's visible from the top, though you may have to remove shielding (if you have it) and get the plug wires out of the way.
Thanks for the decipher everyone. Numbers seem to match up, but it was a resto with NO documentation of the original purchase, the restoration itself or event the miles prior to restoration. Kicking tires at this point, but know even with an inspection I could not buy-in to it being a Mathcing numbers car, as even I would have no way of proving that.
Originally Posted by 856666
just added this
Hi Big Lebowski;
Try this:
4 - 1964, Vin-106831 (The 6,831 first car off the line)
F-Flint, I2-December, 06-Sixth
RE- 327 CUBIC INCH, 365 HORSEPOWER, MANUAL TRANSMISSION
If you compare the stamp date of Dec sixth and the build date below it would appear to line up with original block. what is the casting code of the block?
Phil
I don't have the vehicle in hand, looking at it remotely. I will ask.
Originally Posted by 65GGvert
The letter I (capital i) was used for a 1 in engine stamps.
Very Cool. I did not know that.
Lol, I'll be sure to thank them for that...
Yours Looks just like mine, right down to the RE code.
Same correct 3782870 block, and on the other side you will find the date the block was cast.
Mine was cast L193 Dec 19 1963
Assy date FI226RE Dec 26 1963
Trim tag build date E14 Jan 14 1964
Your car is pretty close to mine.
