What's Faster
Received 3,443 Likes
Since fastest usually refers to top end speed, probably the car with the tallest rear gear ratio.....3.08 or even lower, numerically.
Just another Corvette guy
It would all depend on gearing.
bcwaller (01-24-2019)
I agree. Since all else is the same except engine, my money would be on the big block with more low end torque. But it also depends on the driver. If one of the Brass clan was driving the small block car and power shifting the 4 speed, all bets would be off!
Received 1,121 Likes
2017 C2 of Year Finalist
Stock, factory engines, all other things being equal, if the L36 can hook up, it's at least half a second faster. On the street, on those factory tires, traction is a big "if", so I'd bet on the 327.
Received 2,347 Likes
Beyond the paper differences, the L36 valve train has a greater rpm limiting effect than the L79's lighter weight valve train with a lower rocker arm ratio. The L36 would be more prone to float the valves, with the hydraulic lifters pumping up, earlier than the same lifters in the L79.
In reality the winner would be the engine with the best tune, with both topping out around 135 mph if given enough straight road.
I'm going to shame both with my 300hp 327 with Nitrous!
All right - listen up everyone. We went through all of this last month. Not that it got totally resolved. This isn't going to be one of those KO Wheel type repeating subjects is it?
https://www.corvetteforum.com/forums...ersus-l79.html
Now Ronnie Sox on the other hand..................
Larry
