valve stem seals ?
Old Jan 27, 2019 | 09:31 AM
hedgehead's Avatar
hedgehead
From: I'm not doing as well as I expected, but I never expected I would
Default valve stem seals ?
Got a 65 L79, does it use both the umbrella type and o-ring seals? Did searches but could not find anything definitive.
Old Jan 27, 2019 | 12:58 PM
MelWff's Avatar
MelWff
from the factory, only the O ring.
Old Jan 27, 2019 | 01:01 PM
856666's Avatar
856666
I seem to remember that the oring type were original on both and sometime along the way the umbrella was added to the intake.
I put both types of seals (felpro) on the exhaust and intake but that's just me.
Im sure others will chime in.
Phil
Old Jan 27, 2019 | 01:20 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Only O ring from factory...but you can do much better with a true seal that stays on the guide itself. Viton's etc.
JIM
Old Jan 27, 2019 | 01:55 PM
hedgehead's Avatar
hedgehead
Thanks. I'm doing it like 856666. The umbrellas are sold in sets of 16, so that's how I'm doing it. With the o-ring.
Old Jan 27, 2019 | 05:06 PM
claf's Avatar
claf
Likewise, I used both seals on my 327 rebuild, no problems in 20K miles.
Old Jan 27, 2019 | 06:38 PM
Robert61's Avatar
Robert61
A few things to pay attention to. 1. If you are going to use the umbrella type there are different styles. Make sure the diameter is small enough that the spring doesn't rub it and watch for the thickness at the top. The thin ones are not very good but the thick ones can be thick enough that the retainer smashes them against the guide especially if you have much lift. 2. You can't just put a positive seal on as the guides are not concentric i.d. to o.d. Later in the 80s Chevrolet started machining the guides for positive seals and used both positive and oring for a while.
Old Jan 28, 2019 | 10:13 AM
hedgehead's Avatar
hedgehead
Went with the umbrellas and O-rings which fit very well. the valves had the positive guides on them which looked in good shape, but no O-ring, but as Robert said, I doubt the guides were machined. Now for the " Oh crap" moment, I was down to the last two cylinders and noticed I was going to have one set left over. I was pretty tired, so now I gotta backtrack, and get another set of O-rings as well.
Old Jan 28, 2019 | 07:30 PM
plaidside's Avatar
plaidside
I wrote an article on valve seal replacement on SB Chevy and one of my first instructions is to count the o-rings and umbrellas before you start.
If you want a copy send me you email address.
Joe
To valve stem seals ?
