Pulling a C2's N03 tank
Received 1,391 Likes
2021 C2 of the Year Finalist - Unmodified
2015 C3 of the Year Finalist
The team and I are planning on writing a Restorer article about tanker restoration soon. Having done 2 completely and 3 others as fix ups from previous restorations, I hope to be able to add as much info and pictures as possible about these rare cars. Stay tuned.
Rick Gower (01-30-2019)
I'd never seen a pic of an NO3 tank before. Thanks for posting.
mikelj (01-30-2019)
Here's an interesting picture of the inner underbody under the tank after we removed it. If you look closely you can see a big chunk of the driveshaft tunnel was taken out during its' old racing days. With a Z06 tanker and a 4.11 rear end, you can imagine the punishment it may have taken back in the day. Lucky the broken driveshaft did not punch through the tank, but it was close no doubt. We will repair this properly before putting the tank back in.
The following 5 users liked this post by mikelj:
Brian VH McHale (02-01-2019),
jim lockwood (04-17-2019),
jimgessner (01-31-2019),
Rick Gower (01-31-2019),
Vettrocious (01-30-2019)
Received 1,121 Likes
2017 C2 of Year Finalist
Odd place for a hole, maybe a would-be stereo installer decided to install a speaker there and got cold feet when he drilled a hole and smelled gas...
Received 1,240 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
I've owned 5 of these tanks over the past 40 years. Three were complete, one was an NOS tank only and one a used tank only. I think the 36 gallon tank was one of the neatest options for 63-67 Corvettes.
The following 6 users liked this post by Dr L-88:
mikelj (01-30-2019),
Mr Fufu (04-17-2019),
Rick Gower (02-01-2019),
and 1 others liked this post.
I had a similar experience when re-restoring my blue 63 back in 2012. The car had been body-off restored in 1989, and did well in judging for the previous owner (Bloomington Gold, Duntov, Triple Crown) but after mostly sitting for twenty years it needed a redo.
After pulling the body off, John Hinckley came over and went through the chassis with me. You could still eat off of the frame, but the list of things John found wrong was long and distinguished; it was amazing how much the old pink Judging Guide failed to specify. The fuel tank was blue...Finding all those old rare original parts was a nightmare...
Good luck with Zoe...
mikelj (01-31-2019)
Received 2,127 Likes
I really like reading about these rare options, especially the NO3 tank. Thanks for all the above. Dennis
Ah, sound like we should start a discussion on J56 brakes...........
Sounds good Jim............................ maybe one day.
Count me in Mike.
Count me in Mike.
The following 3 users liked this post by Dr L-88:
Received 1,974 Likes
Back when I was a production engineer at Pontiac in 1968 one of the experienced engineers told me a story about a broken driveshaft at Milford. It happened to a high revving, short geared GTO. The driveshaft broke and came up through the floor pan, but the driver was not injured.
What happened was the rotational frequency of the shaft achieved equality with the natural bending frequency of the shaft, which caused resonance. Think of walking across a 2 x 12 at a construction site. At the right pace that thing will bounce up and down enough to nearly throw you off.
To increase driveshaft bending frequency the diameter and/or material thickness must be increased, or use a two-piece shaft with a center support bearing. Chevrolet did the former for the Cosworth Vega. It's driveshaft is unique by being a half-inch larger OD than regular Vegas to increase the bending frequency for the high revving engine. Fortunately, it's easy to compute the natural bending frequency of a simple geometry part, like a tube of constant OD and material thickness, and the Chevy engineers did their homework.
Duke
I'm sure you're right Duke, the U joint would have been the weak link. I meant to say the driveshaft came through the floor.
#33
Corvette6680, thanks for posting your pics. In the last pic of the exposed area, are the stains the result of your tank leaking in the past? Scary! Dennis
#34
[QUOTE=Bluestripe67;1599232688]Corvette6680, thanks for posting your pics. In the last pic of the exposed area, are the stains the result of your tank leaking in the past? Scary! Dennis[/QUOT
Yes unfortunately
Yes unfortunately
#36
Neat pictures, thanks for posting. Do you know Oliver?
mikelj (04-17-2019)
#40
Most all tanker owners know him, he took over the tanker registry duties from Wayne Midkiff, so I correspond regularly with him.
