[C2] Turn signal switch
Old Feb 11, 2019 | 07:48 PM
Stephen Brozo's Avatar
Stephen Brozo
3rd Gear
Default Turn signal switch
Can anyone recommend a source for a dependable turn signal switch . I have tried the usual supply houses .and have yet to find a quality switch. Thanks in Advance. Steve
Old Feb 11, 2019 | 07:52 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
I seriously doubt you’ll get a recommendation since you haven’t stated the year of the car.
Old Feb 11, 2019 | 08:21 PM
Stephen Brozo
3rd Gear
Default Turn signal switch. Car is a 63
Sorry 1963
Old Feb 11, 2019 | 08:47 PM
kellsdad's Avatar
kellsdad
What are the symptoms that made you conclude your's needs to be replaced? It may be a matter of adjustment.
Old Feb 12, 2019 | 05:10 AM
Frankie the Fink
Army
That's why the year is necessary - 63s are unique from any other year.
The first thing is to make a mark on the cable down by the floorboard at the switch - use a Sharpee pen or some blue tape so you can get the cable back on just like you removed it. Then remove the cable. With the key on move the switch to both extremes with your hand, if the signals work on both sides, front and back - your switch is OK and it may just be a cable adjustment or issue with the mechanical part under the horn button.
If its a cable adjustment then put the turn signal handle at the steering column in the left turn position - put the floorboard switch in the left turn position - tighten the cable in that spot and that should do it.
If the switch is bad then order the NOS one on eBay, the seller has 9 of them:
https://www.ebay.com/itm/1963-CORVET...-/272768694415
Old Feb 12, 2019 | 07:31 AM
Stephen Brozo
3rd Gear
Last fall l replaced the under dash harness. The original switch was cracked and glued but still working but needed to be replaced At this point in time I'm on my third switch. The first one fell apart in my hand when I moved the slide. The second would not move smoothly in would crunch and bind. The third seemed ok but the left side will not flash. A friend who is a Electrons tech traced out all of the wiring and found No problems I'm not a perfectionist but turn signals are nice to have. The switches came from two different sources
Old Feb 12, 2019 | 08:13 AM
Frankie the Fink
Army
Then reach deep and get the NOS one. I could write a novel on some of the crappy repro parts.....most recently, glove box light switches...
To Turn signal switch
